Ionized Fuel for better Efficiency and less prone to KABOOM?
Some of u may have seen this.
But I was talking to an engineer at NASA that I meet at a party last week and he said that he feels that it works.
He went on to say that he installed a unit on his Chopper and noticed that MPG and pwer increased.
The theory was that fuel is positively charged.
THis pushes the molecules apart in the combubstion chamber, thus resulting in more surface area being exposed to air for a better combustion event.
It's basically a similar principle to holding 2 positive ends of a magnet and feeling them push apart.
Anyone guinea pig this?
http://www.cuttingedgefleet.com/purepower.html
http://www.naturesalternatives.com/energy/fuel.html
I would go for the large one since the fuel moves pretty fast through the lines.
We suck up gas like a V-8
At any rate the NASA engineer said that the "finer" the mist or better the atomization of the fuel the better the burn and less carbon builds up.
He noticed that when he changed the oil and later on opened up his engine to look inside.
Said that it was noticeble cleaner.
He said that carbon build up hurts the engine for these reasons:
- absorbs heat and gas (this can act as a detonation point)
- the physical presence of carbon "artificially increases the compression ratio of the combustion chamber since it's mass
- Carbon is abrasive
- On surfaces it acts like an insulator and reduce the effective heat transfer - cooling system effeciencies.
Absolute, positively, completely SNAKE OIL.
It's actually kinda ironic. 15 years ago when I was roadracing motorcycles, a NASA engineer friend of mine (I'm not kidding) convinced me to try a fuel ionizer he developed for the same reasons. I figured the guy's a "rocket scientist", so I said what the hell, and tried it. Granted, a motorcycle's power-to-weight ratio is pretty large, so even a small power increase would be noticeable. I installed the thing midway through the season, and left it there until the end of the year. Result? A huge, monster, massive ZERO. I felt no power change whatsoever, and my lap times stayed the same. When we disassembled the top end after five races, there was the same carbon buildup that we'd usually see in the exhaust ports.
Yeah, in theory it makes a bit of sense. But in practical application, no. Do not waste your money.
Trending Topics
The guy's chopper is probably has an archaic carb, which isn't a very good atomizer, and maybe this 'thing' actually helped. Later high pressure fuel injection systems do a very good job of atomizing fuel, and results are insignificant. Look for it on HSN.....
My engineering professor just showed me some interesting things yesterday that our college is currently working on. One of them is spark plugs that dont use the typical diod/arching mechinism and instead a plasma thingi (im not completely sure how it works) he said that the plugs when fired completely ignight the fuel resulting in a 20% increase of fuel economy, and more power too.
He said the problem with getting something like this to market is that spark plug manufacturers are stocked 5 years ahead and no one wants to let new technology like this get to market, he also that that these plugs are so good that there is no reason they couldent be molded in to the head of an engine.
we also have a crankless piston engine that puts out 280hp and weighs 230lbs and this weird engine that looks kinda like a big bowl and has sleevs that move as it spins... also light and powerful
behind all these cool toys he had a 12a rotary engine taken apart (which i loved to see) but he didnt say anything about it
I work at NASA (LaRC aka: Langley Research Center) here in Virginia. I was involved in several tests using these fuel "ionizers". We tested a small block Chevy v8 (Carter carb), small 2 cycle Sachs single cylinder (83cc), our own 2 cylinder 2 cycle miniature helicopter engines ( opposed twin 40 cc). The small block was tested on a water brake dyno and the smaller engines were inertial dyno’ed using a flywheel type weight the motors had to spin up. A Chrysler v8 (355 cid?) and Ford inline 6 (300 cid) was also road tested in vehicles and our results for all test was ZERO. NO improved power, NO improved economy, NO difference in emissions. We used 5 versions of the same "ionizers". We used standard pump gas and tried different grades and octane ratings. The single cylinder Sachs test was standard pump (2 stroke oil added) and we also configured this engine for heavy fuels (diesel aka: JP-4, 5 or 6). My impression is it’s a waste of time and money and I’ll put it up there with those “Tornado” inlet stationary fan gizmos. Maybe further development in these “ionizers” may result in something actually working to the point it can be measured someday?? As of now there junk.
~Mike.................
These test were done approximately 5-7 years ago, so I can't speak of these "new" ones or if there has been any actual development sense then.
Originally posted by BATMAN
XSTransAm,
Do u happen to go to the University of Maryland?
XSTransAm,
not my first choice of schools, but i think the stigma preceeds it.
I like the pic for the FD3S “as close to the fuel injector as possible for best results” about 2 feet away from the closest injector.
These have been proven on the dyno with accurate equipment to not work at all!
Kinda like that black box filled with potting material and tinfoil with a fuse in it that is supposed to reduce interference and give better HP
