Power FC Set up problems please help
Old Apr 19, 2004 | 08:33 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
I have went through the set up steps 3 times now, reseting the pfc each time. Did the 15min on the 3 different load things and the idle never calms down it acts like it never finishes learning. I cant figure what it would be. Any help would be appreciated.
Thanx
Jeremy
Old Apr 24, 2004 | 03:04 AM
austinsFD's Avatar
Ahhhh Motherland!
maybe something keeps changing
Old Apr 24, 2004 | 03:29 PM
cewrx7r1's Avatar
Eye In The Sky
The ECU can only properly control idle if all parameters are within their normal ranges. If any are outside the normal range then it has problems.
If you did a search of this forum for your problem, you would find answers.
I will say this again for the 1000th time for you newbies: Try increasing or decreasing idle air flow either with the idle set screw on the front of the throttle linkage, or the air bleed screw under the throttle body.
It is also a good idea to check the TPS voltages with the commander.
Marty RE
Aug 17, 2015 09:36 AM
