BLOWOFF Valve theory question!
Old Oct 31, 2001 | 05:48 PM
ROSHX7's Avatar
I was giving it some thoughts lately, maybe a bit too much. But the stock system dumps air back into the intake when you let off the throttle and so the intake has more air to go into the turbo right? Isn't that a good thing? Blowing off that extra air to the atmosphere gives that COOL sound, but is that the ONLY benefit?
Old Oct 31, 2001 | 05:56 PM
AE Turbo's Avatar
Speed from skill
Yeah, I really believe that aftermarket BOV's on moderately modified cars are only good for the cool noise. "They" say something about the rpms not dropping as fast so you can shift better, but I think that's just marginal if anything. The noise really is cool though.
There isn't enough air being put back into the intake for it to make any performance difference. I think the stock BOV is plumbed back into the intake to suppress the noise.
If anyone's looking for a cool noise, disconnect that silencer for the ACV. That deep whine it make at 3000+ rpms is cool enough for me, for free.
Old Oct 31, 2001 | 06:48 PM
Pinfield357's Avatar
whats the ACV?
Old Oct 31, 2001 | 07:29 PM
13BAce's Avatar
On a long vacation
Originally posted by Pinfield357
whats the ACV?
Air control valve. It's located on the lower intake manifold, and it sends air from your air pump to the catalytic converter.
Old Oct 31, 2001 | 07:31 PM
13BAce's Avatar
On a long vacation
The stock BOV is fine for the stock turbo, but if you're going to run alot of boost with a bigger turbo a good BOV can protect your turbo.
Old Oct 31, 2001 | 07:37 PM
Exclamation ACV?
anyone have any kind of tips on disconnecting it?
I have an aftermarket exhaust with a high performance cat and I know that it isn't hooked up to the cat so I might as well disconnect it and if it makes a cool noise hey why not?
Old Oct 31, 2001 | 07:50 PM
turboconv's Avatar
About the blowoff valve question. The reason for them is when you let off the gas and the throttle blades shut there is an excess of air briefly. If this air is not bled off it will dead head the turbo and cause turbulence which stalls the turbo. Stock turbos usually route the air back to the suction side of the turbo to maintain a flow of air through the turbo. So not only do aftermarket blowoff valves sound cool but they actually do have a function.
Old Oct 31, 2001 | 08:32 PM
86Rx7GXL's Avatar
could someone please take a pic and post it of the stock 87 Blow off valve. i just got a turbo 2 and the enigines out with a bad houseing and rest of engine is in box's and i have no clue what the bov is
Old Oct 31, 2001 | 09:30 PM
AE Turbo's Avatar
Speed from skill
Re: ACV?
It doesn't effect the catalytic converter anyway since this the silencer is for excess air. I guess you weren't around when we had a post about this. Here's the link:
ACV Venting noise
Some folks like the noise, some don't. I guess that's why they put a silencer.
Old Oct 31, 2001 | 09:52 PM
Six Rotors's Avatar
It seems to me that the problem with the big external blow off valves is how do correct for the metered air that you vent outside the system?Using the factory ecu air passing into the intake gets an equivalent amount of to be burned with it.If the air is vented you must end up going very rich.
Old Oct 31, 2001 | 10:18 PM
Scott 89t2's Avatar
SOLD THE RX-7!
yes but only when you're off the gas so it doesn't really matter. just makes bigger fireballs
FYI, some other cars, talons etc, don't even idle on the stock ecu when you put aftermarket BOV's on cause they need that metered air...
Old Oct 31, 2001 | 11:25 PM
ROSHX7's Avatar
I don't have a pic, but its NOT hard to locate it. Its near the Passenger shock tower, close to the boost sensor (that little black box with a vacuum line plugged into it). It plugs right into your intake duct and it has a huge line going from it to your turbo pipes that runs up to the intercooler. Hope that helps...:p
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
