Cheap tire patching/sealant.
Old Apr 13, 2004 | 06:41 PM
O 16581 72452 5's Avatar
The infamous number guy!
Just curious my options of tire sealant and patching, i ran over a screw with my Toyos and need something that can deal with agressive driving. I've seen "Goop" advertized on TV and there is "Fix-A-Flat", would either of these be feesable? What are the prices of both? I'll have to save money for either. -_-
Old Apr 13, 2004 | 06:50 PM
SpeedKing's Avatar
Power Trippin'
NEITHER of those is an option for driving of any sort other than getting to a local garage to replace your tire. If you are *that* broke and can't afford a brand new tire, have them remove the tire and patch it from the inside.
Old Apr 13, 2004 | 06:53 PM
It was a brand new, i put it on, pulled into the garage, ran over a screw.
Old Apr 13, 2004 | 06:57 PM
SpeedKing's Avatar
Power Trippin'
Fix-A-Flat is only a temporary fix. Have the tire patched or buy a new one.
Old Apr 14, 2004 | 05:17 AM
maxcooper's Avatar
WWFSMD
Don't use Fix-A-Flat. It tends to pool and will throw the wheel out of balance. It makes a mess inside, too.
Despite many recommendations against doing this for hard-used performance tires, I have used plugs on several tires and it has held up fine. It is the "yarn" with goop on it -- same stuff the gas station uses and the same stuff you can get at auto parts stores. I've never had one mess up the belts or come out after installation. YMMV, but it has worked fine for me.
-Max
rx7jocke
72
Jun 17, 2016 03:48 AM
