Bolts for sway bar
Old Apr 13, 2004 | 05:36 PM
Bolts for sway bar
I felt a rattle the other day as I parked the car. Lo and behold my front sway bar bolt broke from the bottom! Does this have to be replaced by a factory part? 1985
Old Apr 13, 2004 | 09:07 PM
wae's Avatar
wae
You mean the big long bolt that goes through the end of the sway bar?
If that busted, you can replace that bolt, however, it's pretty cheap to get a new set of end links. I reccomend the poly-graphite ones from Energy Suspension. Try suspension.com.
Old Apr 14, 2004 | 01:57 AM
Kill No Cone's Avatar
Hey 1985rx7, you could would cost ytry to get a grade 8 bolt it you $3 instead of $1. I would look at the urathane bushings as well, they are great.
Old Apr 14, 2004 | 05:43 AM
Thanks Guys!
Enzo1944
Sep 6, 2015 08:57 AM
