"Tension Bolt Leak"?
Old Apr 11, 2004 | 10:11 AM
rotarydriven's Avatar
Question "Tension Bolt Leak"?
I was reading through old posts and found something LongDuck posted a while ago.
" if you have a lot of oil leaking from the transmission bell housing (front edge or starter mount), you may have the dreaded 'tension bolt leak' which is caused by the O-ring at the head of each of 18-20 tension bolts that sandwich the engine sections. These leak into the space occupied by the clutch and transmission front cover, resulting in a slipping clutch and oil leak from what appears to be the transmission."
Could someone explain this a little more. I fear I may have this problem......this or front cover seal leak on my trans.
Thanks
Old Apr 11, 2004 | 10:28 AM
mazdaverx713b's Avatar
Have RX-7, will restore
there isnt much more to explain. i suppose it would be like a leaky rear main seal type of deal. if you have the beehive type oil cooler, the rubber o-rings may have dried up and oil may be leaking down onto your engine and transmission making you think the leak is caused elsewhere.
Old Apr 11, 2004 | 01:57 PM
Jeff20B's Avatar
Lapping = Fapping
That's funny because tension bolts seal the WATER JACKET. Yeah, I'd say rear eccentric seal if the oil is like the stuff in the pan, or tranny shaft seal/front cover gasket if the oil is thick and smelly. It could also be oil filter related like from a beehive, or just sloppy oil filter handling during an oil change.
toplessFC3Sman
Mar 20, 2018 01:54 PM
