how to remove old gasket?
Old Oct 29, 2001 | 07:01 PM
tesla042's Avatar
All this damn gasket all over my intake... hard as hell to get off.. any tricks?
-Tesla
Old Oct 29, 2001 | 07:43 PM
1FastT2's Avatar
I use a razor for the big stuff and then I usually switch to a wire wheel on a grinder or something to get the rest off.
Old Oct 29, 2001 | 08:06 PM
1FastT2's Avatar
Old Dec 30, 2001 | 09:26 PM
ka8legend's Avatar
Can we not re-use the old gaskets if they are in good condition and seal it with a little RTV around it ? I hope mine doesn't swell up as I have them soaked in carb cleaner.
I'm getting the metal gasket for the manifold to engine to be safe.
Old Dec 30, 2001 | 09:39 PM
RETed's Avatar
be very careful with razor blades.&nbsp Most razor blades are stainless steel, and that's harder than the aluminum manifolds.&nbsp You can easily gouge the aluminum manifold being careless with the razor blades.
Else, I've found those 3M "Scotchbrite" 2" discs with drill attachment actually work pretty well.&nbsp $20 for the kit?&nbsp I think Sears carries them.
-Ted
Old Dec 30, 2001 | 10:51 PM
CNYRX7tech's Avatar
I also use the 3M roloc products very good results, the discs come in 3 differnet grits. by color green is 50 grit, yellow s 80 grit and white is 120 grit. These are nylon bristle finger type surface prep disk. Most all parts store should have them.
Old Dec 30, 2001 | 10:53 PM
tesla042's Avatar
So i've noticed.. I actually just finished up cleaning the manifolds off tonight.. A few little scratches and scrapes, but i actually found that using 220 grit sandpaper takes the really stubborn gasket off, as well as removing most of the scrapes..
-Tesla
Old Dec 31, 2001 | 12:19 AM
Silkworm's Avatar
Has been.. hangin' around
I'd avoid a wire wheel for anything aluminum.
I agree with Ted, those 3M scotchbrite pads work great.
PaulC
Old Dec 31, 2001 | 12:42 AM
Gene's Avatar
10 lb. boost, 5lb. bag
At the auto parts store u can get a spray can called or stuff called "gasket remover." Spray it on, let it sit a little while, then scrape off with a putty knife.
Don't get it on any paint! It takes it off INSTANTLY! (faster than brake fluid!)
Old Dec 31, 2001 | 02:45 AM
TonyTurboII's Avatar
Glock Lover
I tried this "crap" with very very poor results. Im going to use the #M pad next time.
Old Dec 31, 2001 | 06:40 AM
HAILERS's Avatar
HAILERS
You might consider, when you reinstall the parts, to leave all that rtv, adhesives, etc off and just install the gasket on the clean machined surfaces. Just a touch of a release agent lilke a smear of vaseline on the machined surface that will be llifted off. With two machined , clean surfaces and a gasket you should not need any glue, rtv etc. Just my 2 cents.
Old Dec 31, 2001 | 02:03 PM
turboren's Avatar
That's a good idea.
I've NEVER replaced an intake gasket on any of the engines that I've had to remove just the upper intake. I just use a light bead of RTV around the runner holes. Done this probably a dozen times with no ill effects.
On the other hand, if you're rebuilding the engine, then, duh, yes, go with all new gaskets.
Ren
blackball7
34
Sep 16, 2015 10:10 AM
BLK 93
11
Sep 9, 2015 10:56 AM
