Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Version 3 to Version4
Old Apr 1, 2004 | 06:54 AM
Michael Smith's Avatar
I have been running a version 3 for 3 years and eventually had it dyno tuned and it went great. It had a 3 inch exhaust from the turbo dump pipe and modified air intake with airflow meter removed. std injectors,manifolds,boost would spike to 9 psi. I was using a version 3 wolf3d it made 106 Kw at the treads through a std auto. Now I have had my motor ported and rebuilt with 3 mm Apex and large extend port Hi flow S4 turbo with TO4 compressor ported wastegate and full 3inch exhaust 1000 cc secondry injectors std primary injectors I want to run 15 psi. I wanted to know if anyone had a good base map for a version4 wolf 3D so that I can quickly get it up and running again.
Michael Smith
Old Apr 1, 2004 | 11:43 AM
Fatty_FC3S's Avatar
As far as wiring is concerned, the 4.0 wolf has a section in the back of what wires are re-used and their pin locations. You can use your 3.1 harness, but you will just have to add a few wires from your 4.0 harness (which will fit into the blank pin locations on the main connector) to access all the features.
If you are fairly happy with the map your have from your 3.1, you can compress the X and Y axis on the 4.0 so that it will LOOK like the 3.1 grid (for example, 12% load changes and 500 rpm increments). Enter the values from your old maps into this and the program with "bridge" the values to create a more detailed map. Now you will have something to start with and you can tune from there.
Graham
Old Apr 5, 2004 | 08:50 AM
ok now i have done that now it took me a while to sort the map. I have to setup all the options yet. I only had to sort out idle speed control and boost control wiring according to the manual. I may have to ask some questions with some of the sensor mapping.I will chase up part numbers first.
Michael Smith
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
