replacing struts/springs, anything else?
Old Mar 28, 2004 | 06:04 PM
moehler's Avatar
In the very near future I'm going to replace my stock 95 PEP struts and springs with koni (yellow) struts and eibach progressive rate springs. My car is a daily driver (no track use) and from reading around, this seems to be a reasonable set-up (if you disagree please feel free to enlighten me ).
Looking at pics on the scuderiaciriani website, there are a lot of misc parts that connect the strut/spring to the body (please look here: http://www.scuderiaciriani.com/rx7/suspension.html#DIA , scroll down a little for the diagrams). Are any of these worth replacing or known to wear out (car has 65k on it)? Any rubber gaskets or boots that should be changed with the shocks? Sorry I can't be more clear, I don't know any names for these parts... Thanks.
-Matt
Old Mar 28, 2004 | 07:11 PM
rynberg's Avatar
double post
rynberg's Avatar
I strongly suggest replacing the upper spring seats/dust boots while you are at it. They are only about $42 each from www.mazdaformance.com (highly recommend them) or about $38 each from Mazda Motorsports if you're a member.
part numbers:
fronts (x2): FD15-34-110B
rears (x2): FD15-28-110A
Don't forget to get a 4-wheel alignment after the suspension is installed.
Old Mar 29, 2004 | 11:06 AM
moehler's Avatar
Thanks rynberg... exactly what I was looking for .
t-von
Sep 10, 2015 01:56 PM
BLK 93
11
Sep 9, 2015 10:56 AM
Frox
Sep 8, 2015 08:36 AM
Enzo1944
Sep 6, 2015 08:57 AM
