wtf?
Old Mar 27, 2004 | 02:44 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
wtf?
Okay... I've been driving my 12A-SE since about mid january now... aside from 2500RPM idle and some secondary throttle issues (linkage not connected properly because if I connectct it I have a 7500rpm idle), it's more or less working right.
my carb is hosed, I need a new one or something.. I think that I'll probably get a megasquirt and go EFI over the summer (its my winter car).
Anyways, I'm driving around downtown today and I didn't bother shifting out of 2nd gear while going down a short (500m?) street... I was cruising at 5000-5500RPM for ... 10 seconds maybe? I let off (STEEP hilll at the end of the street) and downshift into 1st (about 7000RPM in 1st.. check hte mirror, WOW SMOKE EVERYWHERE! so I hit the clutch, drive the car home, it smokes once more.. park it, get the groceries out, take it for a spin... I drive it HARD.. the secondaries still open a good bit I think (probably halfway).. its not as fast as it could be but overall it's not that bad. anyways, it doesn't do it again, nomatter what I do to it.. it just acts like a perfect good little wankel.
My theory on what happened: I have an oil seal on the way out, crusing at 5000RPM made the oil pressure go WAY high and as soon as I let off the throttle it all got past the seal and caused the smokeshow....
The car has pretty good oil pressure I think.. at idle (2500RPM) when warm its just past the 4 and cruise at 3500 gets it almost to the 6... I wasn't looking at the gauges when it smoked.
Anywyas, is the engine OK, or should I be expecting serious troubles in the very near future? This car/engine combo needs to last me another 10,000KM (about 2 months) at least...
Thanks in advance...
Old Mar 27, 2004 | 03:06 PM
mwatson184's Avatar
holley guy
You are probably right about the oil seal going out. High RPM + low throttle = very high vacuum, you can pull some oil past the seals and into the combustion chamber under those conditions.
Old Mar 27, 2004 | 03:51 PM
dirty86's Avatar
welcome to my hell
knowing it needs to be rebuilt and not being able to do a thing
Old Mar 27, 2004 | 07:07 PM
Terrh's Avatar
t3h bump
t-von
Sep 10, 2015 01:56 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Wolf_
Aug 11, 2015 04:23 PM
Ryde _Or_Die
Oct 30, 2001 01:48 AM
