Sponsored by: CARiD
13B-REW: Idles at 700, burns coolant, leaks oil...what's wrong?
Old Mar 27, 2004 | 09:21 AM
my name is jason's Avatar
My car is idling at 650-700rpms and sounds/feels like it's about to die. Once the motor warms up and has been drivin for about 20 mins, it begins to smoke from under the firewall area which smells like burning coolant. Then when it's parked it leaves about a 3-inch spot of oil on the ground. Any suggestions? Should I just get my motor rebuilt?
Old Mar 27, 2004 | 01:58 PM
mazdaverx713b's Avatar
Have RX-7, will restore
what year is the vehicle, which type of oil cooler are you using? also, is it leaking coolant on the exhaust manifold or is it being burnes internally. if it is being burned internally, you have a bad water seal and your engine needs a rebuild. we can determine the cause of the leak if we have a location of where abouts under the car it is.
Old Mar 27, 2004 | 03:07 PM
it's a 94. Using stock oil cooler. It's coming from the lower rear of the motor. I will check next time it happens and try to locate if it's external or internal.
Old Mar 29, 2004 | 07:30 AM
zayrx7's Avatar
the mazda zoom zoom store
Could be a coolant seal, you can bring it buy the shop and I can take a look at it for you. www.rx7store.net
Old Mar 29, 2004 | 08:54 AM
yea, i thought it was a coolant seal, how much would you charge to take a look at it?
Old Mar 29, 2004 | 06:24 PM
zayrx7's Avatar
check your pm
Old May 9, 2004 | 05:09 AM
SoloKK's Avatar
The puddle could be from the oil pan. The sweet smell could be the ast or radiator. The smoke could be the turbos, downpipe, y pipe, and/or an oil leak from a loose hose clamp dripping onto a hot engine part.
Good luck...There are a million different possiblities.
Old May 10, 2004 | 10:34 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
welcome to the world of FD's..
whinin
Mar 30, 2019 07:53 PM
troym55
23
May 25, 2016 12:42 PM
