Dash problems
Old Mar 24, 2004 | 02:28 AM
BOOSTED Vert
Dash problems
Ok I know that the dash removal is posted many times and its also in the fsm, which I have, but Im having trouble with the 3 top screws. ok I removed all the vents( which broke), and I removed the center screw. Someone said it was a 1/2" bolt but its actualy a 5/16". Now when I removed all that I couldnt seem to find the other 2. all I see are 2 philip screws on each side, where the bolts supposedly go. The screw holds down a plastic piece which I broke so I know thats not whats keeping the dash from coming out. O I have an 88 vert. Is the dash removal different for verts?? Im still scratching my head PLease HElp..
Old Mar 24, 2004 | 03:59 AM
BOOSTED Vert
ok people sorry for the question I figured it out right away after I hit my head with the dooy on the way out. Since I had the dash out I decided to take out all the ac equipment. wow was that disgusting. There was that nasty black dust along with crusty pieces of foam. I couldnt believe I was actualy breathing all that. I think that cleaning of the a/c should be a regular maintenance that should be completed around every 10 years. Anyway, I removed everything. I havent driven my car for almost a year, but I could remember that the instrument cluster and the switches rattled alot while driving and made my commute annoying. Is there anyway to stop that, or do I need to install another dash ?
Well anyways im tired and I still cant believe I completed a dash and a/c removal at 4 in the morning.
Old Mar 24, 2004 | 04:02 AM
nyc_scorpio's Avatar
R.I.P. Monte Negro FD
those top screws, use a good ratchet on them, there are a total of between 9 to 11 bolts that hold the dash. i recommend once you pull it all out, depending where you live. since i am in florida, the sun beats down on it really bad, i pulled it, sanded it down very lightly, painted it with a UV protection flat coat. after i used a semi gloss clear, bad boy shines, like on armourall, but the shine aint as bad as you think, no glare off the windshield
https://www.rx7club.com/photo/showga...p?ppuser=44780
Old Mar 24, 2004 | 05:23 AM
BOOSTED Vert
Guess you didnt read my second post, but o well thanks anyways. Um yea Im down in miami and the sun is realy bad, but the only damage on my dash is the damn defrost vents, which broke as soon as I even thought about touching them. Thanks anyways
Old Mar 24, 2004 | 09:58 AM
totallimmortal's Avatar
Is that thing Turbo?
hmm half inch? 5/16? should these bolts be metric like the rest of the car?
Old Mar 24, 2004 | 03:35 PM
BOOSTED Vert
well I dont know but I used a 5/16 closed end wrench to get it.
Old Mar 25, 2004 | 01:47 AM
i hear that man, i had to buy new vents for my ride, i ordered them from mazdatrix. both lefdt and right with shipping was around 50 bucks, these i also spayed UV protection paint cause you know it, the sun here in the dirty south is no joke lol
Old Mar 25, 2004 | 02:12 AM
BOOSTED Vert
yup its crazy down here, did the vents come with the piece which holds the VIN ? Hey so where in fl do you live?
Old Mar 25, 2004 | 03:52 AM
yeah man, it comes ready to slap the vin plate on it, careful removing the vin plate, its made of tin foil hahahahahahah i am in orlando,
Old Mar 25, 2004 | 03:54 AM
BOOSTED Vert
yea man the plastic underneath the vin disintergrated in my hand, I was like WTF. Wow orlando, damn it gets hot up there. I remember going to the them parks, its almost like crossing a desert during noon time.
Old Mar 25, 2004 | 04:05 AM
for sure man, its all for the damn tourists, they make all the streets unsafe too, some of these come with driving licences that come in a craker jack box, last time i had this damn french family that opened there door and banged into my car, i was likw WTF you crossant making fokers, cant you see my car here??? I made a big *** scean and got the inssurance company to give me a 450.00 check on the spot hahahahaha viva pepe le peu
Old Mar 25, 2004 | 04:06 AM
hahaha same thing happend to me man, i pulled the vent and it just became dust, i was like, holy crap hahahahaha
Old Mar 25, 2004 | 04:43 AM
aka_rocket's Avatar
7s bein a pain in the ass
hey, um...hopefully you got the dash out. i just did it last week so i'll say what i did and hopefully it helps a little. the top pieces, with the vents, since you broke those vents then i guess that it for them. now the center screw, that's the only thing you need to get off now. now the metal piece cover the dash, the piece that the vents were screwed onto. use a flat and hopefully not scratching anything, pry the piece off the dash. they should pop off. its held in with metal so just pop it off, sliding the flat across the dash. once you have that metal piece off, kinda pull if up and wiggle it sideways up onto the a pillar and window. this part is tricky. you will see the three main screws that connect top of the dash to the car. i think those are 10mm. the side vents (by the door) you can pry them off with a flat as well. please be careful though since RX-7 plastic is so freakin weak. once you get those off, you will see two screws, undo those. undo for both sides then by the centerpiece, you see the little plastic piece you can take off. a little piece of carpet covers the last two screws. get those off and your done. just lift wiggle and tilt and pull out. all this assuming you've got the cluster and steering wheel and such off. oh, wire wise, there are two on the driver side (color blue) and one under the glove compartment (blue also). i might have missed a wire but yea, that should get the dash off. then you have the hoses too. remember where each goes. i forgot to put some AC hoses in before i put the dash back in. that REALLY freakin sucked for me...but i fixed it. hope this helps.
oh yea, the vert is the same. i did my 86 gxl first since i wasn't sure how. then i removed my 91 vert's dash also(needed the temperature actuator for my AC system). only took me less then 20 minutes. it really is easy, just afraid to break those weak plastic.
Old Mar 25, 2004 | 03:42 PM
BOOSTED Vert
Damn that lady must had a pretty good insurance. Anyways you think turists are bad, you should come down here and see how the people drive in hialeah.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
