T2 rear end in a N/A
Old Mar 23, 2004 | 12:01 PM
87weber's Avatar
Can a turbo rearend from a 87 TII be swapped right into a 87N/A? Im talking about the whole subframe and differential. I know that the non turbo driveshaft wont bolt up, and the lug pattern is different, but we have that taken care of.
-Ben
Old Mar 23, 2004 | 12:42 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
the splines on the end of the driveshaft that goes into the tranny are different as well between NA and TII. However, the mounting points are the same on both cars, the entire subframe is swappable.
Old Mar 23, 2004 | 04:59 PM
87weber's Avatar
thank you
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
