Tire and wheel size compatablilty??
Old Mar 22, 2004 | 06:27 PM
i have a stock 13 in 1st gen rim with tire size 185/70 13. is there any wiggle room in tire size? Like could i have a 175/70 13?? or a 185/80 13?? THANKS
Old Mar 23, 2004 | 04:45 PM
comon this should be easy for you rx studs!!
Old Mar 24, 2004 | 03:14 AM
maxcooper's Avatar
WWFSMD
Look at the spec sheets for each tire model on tirerack.com to get the recommended rim widths (find out your rim width for comparison). I am not sure how sensitive the tire diameter is for the SA/FB (before you rub), but perhaps someone will chime in with some tire diameter recommendations.
-Max
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
