bigger brake master cylinder
Old Mar 16, 2004 | 11:09 PM
Is there such thing as a bigger bore, brake master cylinder? One that will come close to fitting a first gen?
Thanks, Andrew
Old Mar 16, 2004 | 11:49 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
i believe the SE one is bigger.
otherwise you could look at a race unit, but you would have to add proportioning valves and such. But that would be badass.
Old Mar 16, 2004 | 11:52 PM
yeah... gonna shove second gen front subframe under an 84, with coil overs, and poly bushings, but I dont think the stock master will cut it, un sure.... I know it probably would, but I would feel safer with a better mastercylinder....
Any more suggestions, anyone?
Andrew
The1Sun
Sep 15, 2015 04:45 PM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
