Sponsored by: CARiD
factory fog light
Old Mar 14, 2004 | 10:41 AM
factory fog light
does anyonw the wiring for the factory fog lights to a 90gtu.....i need to rewire them and i have no clue where to start from......
Old Mar 14, 2004 | 11:55 AM
domesttuner's Avatar
CVPI rules the road
are the wires still in the car?
Old Mar 14, 2004 | 02:58 PM
mazdaverx713b's Avatar
Have RX-7, will restore
do you have any sort of shop manual for your car?
Old Mar 14, 2004 | 11:50 PM
CVPI rules the road
if the lights are still in the car, tie w string to the origin point, then pull out the wires. if you left the string long enough, the string will now be were the wires were, making the rerouting easier - just attach the wires and pull them back in. provided, of course, if the light's wires aren't in the harness
if they are out of the car, then i don't know. you could always wire them your own way, if you are good at making harnesses and such
Old Mar 15, 2004 | 11:50 AM
yeah lights are on the car...and no shop manual....the last owner had aftermarket ligths on it...
Old Mar 15, 2004 | 12:02 PM
CVPI rules the road
try running some extra wire through the mounting areas, then seeing the easiest way to run them to the interior to the switch area. you might figure it out easier that way.
rx7shirley
Sep 2, 2015 02:11 PM
