Best clutch disc?
Old Mar 13, 2004 | 08:23 PM
Jahoo88's Avatar
Best clutch disc?
Hi, what do you guys suggest i get for a clutch? I have all the bolt-ons done on my stock S5 turbo engine running 14psi. I have a stock disc/30%+ pp in the car now and its sliding all over (3000mi). I think i glazed it over at the track, but it never felt strong to begin with.
Im going with an 11lb Mazdaspeed flywheel now and i want to stay away from copper or ceramic puck clutches (ACT) to save the flywheel.
Will a Kevlar disc glaze over during drag launches like an organic one will?
Is there any other material i should be looking at that can take 5000 rpm clutch dumps but can also be slipped a tiny bit daily driving without chewing up my flywheel?
Old Mar 13, 2004 | 09:13 PM
rotarypower101's Avatar
sdrawkcab
You might want to consider the pineapple clutch that rob makes.
Only thing is, is that its engagement is real quick.
But it is not a material that will chew up the disk fast if that’s what you are looking for.
http://www.rx7store.net/product.asp?0=206&1=241&3=787
risingsunroof82
Sep 9, 2015 08:06 PM
