What do i need to finish off my 45 webber and intake?
Old Mar 10, 2004 | 11:08 PM
12a weber intake kit.(45DCOE)
This kit includes ( 1) 45 Weber DCOE carb with linkage, intake
manifold,velocity stacks, air filters ,all nessisary gaskets/o-rings needed
to complete the job this kit will work best on stock motors with exhaust and or ignition upgrades.. Ads up to 60 hp over the origonal Nikki carburator!
..........$550.00
ordering it tommarow, what else do i need, i need CHEAPER THE BETTEr. Where can i get a fuel pump, and what type do i need? Is a reg neccesary?
Old Mar 10, 2004 | 11:16 PM
Chamele03's Avatar
i am looking at that setup myself, iI emailed rotaryshack and they said on a stock motor nothing more is neede other than the kit.
Old Mar 11, 2004 | 05:48 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
1. High volume fuel / low pressure fuel pump (either Holley, Mallory, or Weber Redline).
2. New fuel filter
3. Fuel pressure regulator (capable of regulating down to 2 psi and up.)
4. K&N filter cleaner and charger
5. New fuel line hose
6. Vacuum plugs to cap off fuel return.
7. Possibly longer vacuum hose to run brake booster from intake manifold
8. Possibly new hose to run your OMP lines. (Ask rotary shack if he includes fitting on the intake manifold for the OMP as well).
9. Hose clamps (various sizes).
10. Various and sundry vacuum plugs for other stuff rendered useless by mod.
11. various and sundry tools.
12. 12 pack of beer (quality stuff- remember, you ARE installing a Weber).
Anybody else got something?
Old Mar 11, 2004 | 05:55 AM
timmya2's Avatar
thats pretty much it dude
Old Mar 11, 2004 | 10:20 AM
Tom's Avatar
Tom
Oh- let me add this:
13. Fresh antifreeze (if it has not been changed in a while)
14. New intake O rings
15. New intake manifold gasket
16. More beer (if you have helpers)
Old Mar 11, 2004 | 10:25 AM
QuagmireMan's Avatar
Registered Offender
why would you cap off the return?
Old Mar 11, 2004 | 10:30 AM
Tom's Avatar
Tom
Thre is no return fuel line on a Weber (in most cases). It's not needed.
In fact- when I ran a 45 DCOE and tried to use a fuel return, my fuel pressure would not build past 1-1.5 psi no matter what. Cap the return and 'voila'..Instant 4 psi.
rgordon1979
40
Mar 15, 2022 12:04 PM
