Haltech 20b E6k
Old Mar 10, 2004 | 07:11 PM
20B-3Rotor's Avatar
Haltech Dealer
20b E6k
Is anyone running a 20b with 1600cc sec inj. If so would you be able to show me your Map
Old Mar 11, 2004 | 03:53 AM
RETed's Avatar
Um, why?
NA?
Turbo?
Stock turbos?
Sequential?
Non-sequential?
Single turbo?
Which single turbo?
-Ted
Old Mar 11, 2004 | 12:27 PM
20B-3Rotor's Avatar
Haltech Dealer
Stock turbos
Non-sequential
street port
550 primarys
I just put the 1600cc in, i thought somebody might have a fuel map for it.
Old Mar 11, 2004 | 03:51 PM
$150FC's Avatar
Currently Winning
I did not think one could control a 20B with an E6K.
Assuming you could, I would look at a map for maybe an REW engine and extrapolate.
Old Mar 12, 2004 | 12:40 AM
johnisenglish's Avatar
You can use the E6K and have it treat the 20B as a V6, firing the leading and trailing plugs at the same time. Not ideal, but inexpensive and it gets the job done.
As far as maps go, use a basemap for a 13B with similar porting, as the fuel trim per rotor will be fairly close. That'll at least give you a decent starting point to tune from. Just make sure to setup all the engine information (firing order, etc) correctly, as it'll be different.
