widest tire on 7.5inch rim
Old Mar 5, 2004 | 12:27 AM
Godzilla-T78's Avatar
as title states.. how wide of a tire could I put on a 18x7.5inch rim.. What would your recommend for best handeling...
Old Mar 5, 2004 | 01:05 AM
88IntegraLS's Avatar
Displacement > Boost
I'm guessing 245 width is the maximum you could stretch over a 7.5" rim. I would recommend 225 to keep the tire sidewalls as perpendicular to the road as possible.
Old Mar 5, 2004 | 07:19 AM
Scrapiron7's Avatar
STi Boxer power!
That's a bit narrow for an FD.
Old Mar 5, 2004 | 12:11 PM
AsianRX7's Avatar
i like 245/40 up front
Old Mar 5, 2004 | 12:19 PM
riiiiiiiiihgt
you have got to be kidding. have you ever tried to put a low profile 245 on a 7.5" wheel?
the absolute widest i would go on a 7.5 with a 40 aspect ratio would be a 225. Anything bigger would suck for handling response and tire wear.
My rule of thumb for correct tire-wheel fitments. If the guy putting it on has to use two tire bars and/or has to work really hard to get it on there, the tire is too wide for the wheel.
someone needs to sticky a Rule Of Thumb or something so these people stop asking if they can put Vette tires on 17x7s.
divide the section width by 25.4 to get inches.
225/25.4=8.6inches. this is already over an inch wider than the rim. Anything over an inch wider than the rim will negatively affect turn in/response, etc. when compared to a narrower tire on the same wheel.
I try to stay under an inch when I put performance tires on my cars. if a mod wants me to write up a more coherent General rules of Tire/wheel ratios i can.
Old Mar 6, 2004 | 11:20 PM
Carl Byck's Avatar
Mad Man
More coherent is definitely something you ought to consider Do you own thwe wheels already?
A 245-45 is fine, a 245-40-17 is also OK, but a 245-40-18 is pushing it. As an Example, I run a 255-40-17 V700 R compound on an 8" rim, sugeested is 8.5-10, but I have perfect temps, and wear with the 8" rim. Alot depends on the rest of your set-up. That said, the 7.5 is really narrow for an FD, that's 1/2" narrower than stock. If You have 7.5s, and love the wheel, you could have them widened, for 250.00-350.00 per wheel. Carl
What's this "powah" thing anyway...
Old Mar 7, 2004 | 03:50 PM
powah
yeah i was frustrated at all these people trying to put steamroller tires on Honda rims. I had also just replied to like ten similar posts in the past two days on the same topic. If you like having your tread stick way out past the edge of the wheel, thats your thing, but i prefer razor sharp handling over all out grip. I had 245/45/17s on 7.5" rims on my 240. they would grip well, but you could actually feel the weight shift as the sidewalls flexed. And this was with stiff *** tires. (AZenis Sports.) And the "powah" is because i was lazy and had just gotten my FC, was the first thing to pop into my head, since the name i wanted to use was taken. (SuperFC, as i go by on other forums) im white, too.
Old Mar 7, 2004 | 07:53 PM
Well I already paid for em ect.. They are Racing Hart c5's He has 235x40x18 on 2 and the other 2 have no tires.. So Iam trying to figure out what sizes to put on the other 2....
Matt
Old Mar 8, 2004 | 08:11 PM
mark57's Avatar
Temple of Cornd0g
215 is the widest you can go on a 7.5.
Old Mar 8, 2004 | 08:14 PM
mark57's Avatar
Temple of Cornd0g
215 is the ideal width for a 7.5" wheel.
Old Mar 9, 2004 | 12:43 AM
anobii's Avatar
225mm=8.86" - sectional width is pretty much irrelavant for exact sizeing. the only way to be 100% sure is to measure tread edge to tread edge, and on a 7.5" wheel the tread width should be as close to 7.5" as possable for the best traction, treadwear, and response.
it is very possable to have a 215 wider than a 225, 235, and even as much as a 245 in extreme cases as far as tread width is concerned. Lets take a 225/50/16 for example. 225= the sectional width in mm, not tread width. 50= percentage of sectional with, or 225 x .50. and 16 is, well, you know what it is. Sectional width is the width of the tire from sidewall to sidewall at its widest point on a given rim. A friend a yokahama told me that there is NO standard for what rim size is used when calculating sectional width. Most manufacturers spec a 195-225 tire on a 6" wide rim, but that also changes with performance type. In other words if a 225 tire that was spec'd on a 6" rim was put on a 7" rim would yeild a sectional width of 235 and 245 on an 8" rim (10mm per inch) . But the tread width would not change. So in other words a 215 tire spec'd on a 6" rim and a 225 spec'd on a 7" rim could indeed have the same tread width, and pretty much in essence be the exact same tire size. Sidewall thickness is also an important point, as a thicker sidewall would not bulge as much, and in turn, make the tread width wider. Like a 225-40-16 bridgestone SO2 pole posistion would have a greater tread width than a 225-70-16 bridgestone turanza. So hey, maybe treadwidth can increase as the aspect ratio decreases, since the sidewall is stiffer on lower series tires.
just thought id share.
-E
Old Mar 9, 2004 | 12:47 AM
uhhh. ok. I was just providing a very basic guideline. i know about all that **** ive been in the tire industry (sales/service/aftermarket) for almost three years.
Old Mar 9, 2004 | 12:52 AM
anobii's Avatar
Sorry, i wasn't trying to step on your toes. I'm just bored
Old Mar 14, 2004 | 10:47 PM
so put the 235s in the rear and put 225s on front or try to stretch 245s on for the rear or do 235s all around?
rx7jocke
72
Jun 17, 2016 03:48 AM
