using CFM to determine fuel needs?
Old Mar 4, 2004 | 08:29 PM
Barwick's Avatar
SCCA Rookie
Is it possible to use the absolute MAXIMUM CFM to determine (at 80% duty cycle) the maximum size injectors you'd need on a car to get, say... an 11:1 ratio? Or to be safe, a 10:1 or even 9:1?
Old Mar 4, 2004 | 08:45 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I think you would need to know the density of the air, maby lbs/min instead of cfm?
Im no expert, but im learning, to figure that out i think you would need to also know
1. Current VE
2. RPM
I think thats it, lbs/min takes care of of temp, humitity etc i belive, however experts will soon chime in give a more detailed explination
-Jacob
sherff
Sep 12, 2015 12:22 PM
