Compression on the 3rd gen 7
Old Oct 23, 2001 | 01:15 AM
LetsGO7's Avatar
What's the compression on our cars (FD, US spec engine)? I know it's 9.0 now in Japan with stronger apex seals and more boost (damn!).
Thanks
-joe
Old Oct 23, 2001 | 01:25 AM
LetsGO7's Avatar
is it the same?!?!?
thanks
-Joe
Old Oct 23, 2001 | 07:07 AM
airborne's Avatar
King of the Duct Tape
i think the 'standard' is like 7-9 though thats the source of some debate, and there are different ways/units to measure it with...
Old Oct 23, 2001 | 10:09 AM
Do you mean compression ratio or the measure of compression to see if the engine is still in good working order?
There is a chart in the shop manual the shows the acceptable compression of the engine versus engine rpm....
It is roughly 7.0 kgf/cm^2 @ 250 rpm.
Patrick
Old Oct 23, 2001 | 04:16 PM
Nathan Kwok's Avatar
Don't mix up compression ratio and compression pressure. The compression ratio is 9.0/1, that is just a static value that relates the ratio of the volume of the combustion chamber between TDC and BDC. The compression pressure is spec'd at 8.5kg/cm^2 or 120psi from the factory, with a minimum of 7.0kg/cm^2 or 100psi, with a maximum difference of 1.5kg/cm^2 or 21psi between the chambers. The minimum was eventually lowered to 6.0kg/cm^2 or 85psi. I've only seen a few people actually test in the 8s, with most being in the 7s or 6s however.
Rotospectre
Sep 13, 2015 11:22 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
