Leading and Trailing
Old Feb 18, 2004 | 06:35 PM
JCurry's Avatar
Shpee
What is the difference between A leading spark plug and a Trailing spark plug, are they interchangable and what will it do if you interchange them, also does anyone have any pics of them so I can see the difference.
Justin
Old Feb 18, 2004 | 06:48 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the only diff is one number in the plug serial number. and they should also have an "L" and "T" written on the plugs.
the heat ranges are slightly different.
if you swap them the car will still run.
leading are the lower ones
Old Feb 18, 2004 | 06:51 PM
Rattaan's Avatar
we...yota...
I think the leads have two blue stripes around the ceramic. Or maybe the trails do? They match to the original ngk wires though. The difference is the heat range.
Old Feb 18, 2004 | 11:22 PM
J-Rat's Avatar
Alcohol Fueled!
IF that fails, the plugs have a handy little "L" and "T" on them. Wonder what those stand for?
Old Feb 19, 2004 | 12:12 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
L=leading=lower
T=trailing=top
easy way to remember
dona1326cosprings7
Oct 29, 2015 06:47 AM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
