Manual rack install
Old Feb 18, 2004 | 04:07 PM
Kenteth's Avatar
Like Ghandi with a gun
Manual rack install
So.. the manual rack showed up today, looks excellent. Plan to install it after we get the tranny mounted in.
After I install the manual rack (currently we have a p/s rack), I assume I need to get the car alrigned at a shop. correct? Otherwise how do I know everythign is straight?
Old Feb 18, 2004 | 04:11 PM
nashman69g's Avatar
Boost Addict
You only can eyeball a certain amount then you need to take it to a shop and let them use a machine to do the rest...If you eyeball it you will be putting a big strain on your wheelbearings and they'll wear out quickly if you don't get them aligned!
Old Feb 18, 2004 | 04:27 PM
Kenteth's Avatar
thats what i figured, thanks! but good for the 10 mile drive to the alignment shop, right?
Old Feb 18, 2004 | 04:33 PM
WAYNE88N/A's Avatar
try measuring the distance from a fixed point on the frame to the jam nut on the tie rod end (near the knuckle connection), both sides...use the same distances when installing the new rack- that oughta get you within 1/8 inch or so, if not better
Old Feb 18, 2004 | 04:43 PM
nashman69g's Avatar
Boost Addict
Yea, I drove my N/A 10k miles on eyeballing it...I had a lot of vibrations and of couse I destroyed by bearings but you can drive it for 10 or so miles and be OK...It wasn't until about 1500 miles before it started to go bad...AutoXing didn't help either!lol
astrum
24
Nov 15, 2017 08:44 AM
betes
Aug 25, 2015 05:09 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
