need help finishing removing heater/ac
Old Feb 16, 2004 | 01:27 PM
enrique's Avatar
I removed almost everything. still need to get this out :
from the looks of this:
there are 2 lines that carry the coolant into/out of the unit. from reading some of the messageboards I need to either cap these lines or loop them together. since I haven't been able to download/find the correct FSM with these particular diagrams I am kind of stuck as to where these lines route to up front.
I also need some help as to where these lines route so I can take them out.
fullsize pics can be found here
thanks in advance
Old Feb 16, 2004 | 03:28 PM
nashman69g's Avatar
Boost Addict
In the second pic there is no need to route the line together coolant goes in one side and out the other...but if you are removing the first thing in pic 1 then there is no need to do that at all--but make sure you cap off the lines coming from the lower radiator neck and the bung coming from the engine next to the oil pressure sending unit!...Now in the third and forth pic the lines go to the condenser (the radiator looking thing) and also the drier (the metal canister) in the front of the car--you can see this stuff better if you remove the black plastic from in between the bumper and the car!
Old Feb 16, 2004 | 06:39 PM
enrique's Avatar
thanks. i just went and tried it blind. I was able to take out all the ac stuff. still a little unclear on the heater and where the coolant lines route to and from.
still need a FSM with these diagrams.
Old Feb 17, 2004 | 10:40 AM
enrique's Avatar
bump for diagrams
BLK 93
11
Sep 9, 2015 10:56 AM
risingsunroof82
Sep 7, 2015 01:11 PM
