Audio Question need help
Old Feb 13, 2004 | 06:46 PM
PhatManBUD's Avatar
I have a kenwood 250 watt amp powering my 10" sub, i was listening to music one day and the bass went out, i dont know what happended, didnt smell anything, touched the amp and it wasnt hot or anything, what do you think could have happend, how come its been like 1 week and the bass hasnt come on, do you think i blew my subwoofer? what should i do to fix it/
Old Feb 13, 2004 | 07:33 PM
rynberg's Avatar
You need to do some actual troubleshooting.
*does the amp power up?
*verify that signal wires to amp are still firmly connected at both the amp and the headunit
*verify that speaker leads are firmly connected at both the amp and the speaker
*did you blow a fuse on the amp?
*verify that your headunit is still sending signal to the subwoofer
I doubt you blew the speaker, because it would still try to work and it would NOT sound pretty.....
Old Feb 13, 2004 | 10:05 PM
darkside7's Avatar
ck your amp fuse
Old Feb 15, 2004 | 09:04 PM
ckyguy's Avatar
ex-rx owner
if you blew your sub, you'll hear a crackling noise instead of bass, if you don't hear anything, its either you blew a fuse, fried your amp, or one of the wires isn't connected enough. if your amp turns on, then off really quick when you turn the ignition, you either have a bad ground, or the remote turn on wire isn't connected firmly, if it doesn't turn on at all, check all wires and fuses.
Old Feb 15, 2004 | 09:05 PM
teamafx's Avatar
check the ground
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
