Tires
Old Jan 27, 2004 | 04:29 PM
J.S.J's Avatar
Tires
With a all "stock" 93 base model, stick, what are the largest tires that can fit in the rear? If I wanted to srarch this I would not have posted it.
Old Jan 27, 2004 | 04:37 PM
bajaman's Avatar
Constant threat
Probably 245 wide 40 series tires, all stock. You may experience some fender rubbing.....
Old Jan 27, 2004 | 04:39 PM
rynberg's Avatar
Stock rims: 245/45 16
17" wheels: 275/40 17 on 9-10" wide rim, may need aftermarket trailing arms to clear inside of wheel depending on wheel offset
18" wheels: 285/30 18 on 10" wide rim, again, may need aftermarket trailing arms to clear inside of wheel, depending on offset
blueskaterboy's Avatar
Olympic Muff Diver
245 45 is what im using on stock rims
Old Jan 27, 2004 | 04:45 PM
J.S.J's Avatar
Thanks for the input, I really like the look of off set size from front to rear, but I don't like the idea of grinding up the car.
rx7jocke
72
Jun 17, 2016 03:48 AM
