12A intake flow?
Old Jan 27, 2004 | 11:50 AM
GlobalSport's Avatar
12A intake flow?
I'm thinking about carb mods, but am interested in what the stock 12A intake manifold flows by itself. Why increase carb flow beyond the ability of the intake manifold, right? I'm sure that it's been talked about already, but I couldn't find specific numbers. Thanks!
Old Jan 27, 2004 | 12:37 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
I don't think you have to worry about out-flowing the manifold. RX7Carl does carb mods and his carb is flowing more than 400 CFM compared to the stock carb flowing around 300 CFM.
Old Jan 27, 2004 | 04:31 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
Flowing just the carbs or with manifolds?
if with manifolds, are they same?
Old Jan 28, 2004 | 12:23 AM
alien_rx7's Avatar
Interstate Chop Shop CEO
bump....GS makes a good point, what exactly is the maximum flow of a stock 12A intake?
Old Apr 1, 2005 | 01:58 PM
this is a very interesting point ...Sterling or Carl can you guys please post your opinion?
Sorry for bringing this post from the dead
Old Apr 1, 2005 | 02:16 PM
calvinpaul's Avatar
Mmmm Cheeze....
Mmmm old post, I believe Carl has been working on improving the stock intake manifold. I am not sure if he is quite done with it or not though.
Old Apr 2, 2005 | 08:58 AM
Rx7carl's Avatar
Airflow is my life
The manifold is restrictive and is in need of improvement. I have worked out the details to make it a dual plenum with smooth flowing and ported runners. Numbers arent here (im at work shhhhhh) but anyway, its not necessary for the manifold to flow as much as the carb since even the ports on the plates wouldnt support that much airflow. Its most important for it to flow enough for top end without losing velocity for low end performance. If you made it flow enough to maximize peak power it would have no low end whatsoever.
Oh and the Sterlingcarb flows 465CFM's as of the end of last year.
Old Apr 2, 2005 | 10:06 AM
rustnrot's Avatar
In the interest of The Future, what year cores should we be saving?
Old Apr 2, 2005 | 10:13 AM
Rx7carl's Avatar
Airflow is my life
SA's would be preferable, but Im able to mod shutter valve ones also. The easiest and best are the RX-3's. Theyd need the least amount of work.
Old Apr 4, 2005 | 11:07 AM
anyone have a pic of an rx3 sp intake?
Old Apr 4, 2005 | 03:15 PM
WackyRotary's Avatar
standard combustion
I have a 70's 13b 4port intake manifold (unknown which model car) if that helps?
Old Apr 4, 2005 | 09:55 PM
lovintha7's Avatar
Suicidal Death Missile
I think Sterling DID actually flowbench the stocker intake, but never posted the numbers. I'm curious also on what the stocker actually did flow.
Old Apr 5, 2005 | 07:37 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Carl does all the flowbench testing.
