Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Wide band?
Old Jan 22, 2004 | 01:51 PM
Question Wide band?
Hi All,
I am intrested in buying a Wide Band set up but dont know much about where to get one and how much they cost?
Do they get better the more you spend on one or do they all basicly do the same thing? What i'm trying to say is in your opinion is a top of the line Wide band much of an improvement?
I dont want to fit it to the Car so i'm not woried about looks.
Thanks
Chris
Old Feb 6, 2004 | 12:25 PM
Trevahhhh's Avatar
check out www.tuneyourengine.com
they go for about 350 ... and is a veryyyy good system .. alot of the VW people have them and have been happy with them .. it has dattalogging abilities which you can load to you comp and it comes with the software for that ,,, if you want it RPM sensing i think its another 100 dollars . sorry i couldnt awnser any of your other questiosn .. but definatly check it out some of the top VW tuners suse .. for example 600whp vr6s
Old Mar 5, 2004 | 11:23 PM
ZoomZoom's Avatar
SEMI-PRO
I have been shopping for a wideband and decided on the FJO. The reason was it seemed that some other brands like "Bosch", although are good products they dont hold up as well to the heat of the rotary engine. Some guys still use them with success but i think they put them further back away from the turbo. From what i understand its less accurate the further back you go but its marginal. Also i got alot of good feedback about the FJO and the price is only slightly higher. But if your on a budget i hear there are some good sources for inexpensive kits. Check out the PFC forum for more info and feedback from other users.
Old Mar 9, 2004 | 05:27 PM
sevenin7's Avatar
zoomzoom i would like also to buy a wideband . What do you think about Techedge ? Its australian product too .
Old Mar 9, 2004 | 05:29 PM
Jason's Avatar
The one
http://www.rx7store.net/subcatmfgpro...208&1=361&2=-1
Logan Reinisch
44
Sep 17, 2018 12:20 PM
manoflego
19
Sep 30, 2015 05:19 AM
