Good single 10-12" Sub for FD *Tight* install?
Old Oct 16, 2001 | 02:30 AM
daiSho's Avatar
hi all... ok, i'm getting my FD back in a day or so and need to figure out what to do about my stereo situation... i had a custom box holding two JL 10" behind the storage area at an angle, but i just upgraded my whole fuel system and now have a surge tank sitting right there, so my only space for a sub will be either in the spare tire well (fiberglass, ughh) or a very slim enclosure near the total back of the storage area, right undr the hatch. should i use one of my JL 10"'s for this need, or do i need a sub that is made for lesser airspace? i'd like to recycle here, any advice from others who have had to deal w/ very little room on an FD for a sub install? i'm not sure where to start... thx all.
Old Oct 16, 2001 | 02:56 AM
spyfish007's Avatar
Yellow Dragon is no more
JL 10WX? Need to know what series. If it is the 3 or the 6 then keep and put in a 0.625 ft^3 box .. you will be happy but probably not as happy as your ported box. Also consider going with a Boston sub ... very tight hard bass. You can add a bass cube from Phoenix gold to either setup to get some SPL back. Sell one sub and get some $$ for the bass cube ... they are like $200 retail or $150 off the internet. You get a **** to mount to control bass from the driver's seat .. way cool and really effective!
Old Oct 16, 2001 | 03:05 AM
daiSho's Avatar
base cube? is this a sealed sub w/ a power source? i guess i should have mentioned... i have a nice PPI 5x200 amp that i'd like to recycle in the system... can i power one of these 'base cube's you mentioned off of it? a drop-in solution would be so nice, as i'd like to be able to pull the sub unit when going to the track... thanks friend.
Old Oct 16, 2001 | 03:37 AM
daiSho's Avatar
ah, sorry forgot to answer... 10w6, about 1 year old
Old Oct 16, 2001 | 03:47 AM
spyfish007's Avatar
10W6 .... ah good sub!! The bass cube goes before the amplifier and extracts the most from the amp. It is really cool. Go to the Phoenix Gold web site. Many manuafactors use this piece of eqiupment to show off their amps and subs.
Old Oct 17, 2001 | 08:57 PM
dnewman's Avatar
The JL 10W6 is a very nice sub I have three of them laying around my house waiting for a new application.
Here are a few others to consider
Blueprint 1001 or 1201. Both are at least the equivalent of the 10W6. With more xmax and similar effeciency, they are a good choice. For 69.00 and 79.00 respectively, you cannot get a better woofer for your money.
Adire Audio Shiva (115.00) outperforms nearly any other sub 200.00 woofer on the market for a lot less money. If you could give it 1 cu ft, you'd be happy with the results. This sub outperformed the three JL10W6s it replaced when it comes to SQ, and came close to equaling the output.
ONe more interesting option would be the Phase Linear Aliante sub. It's total depth on the 12" version is only about 3". It may only be available in Europe, and it's $$$ but would make for a killer sub in this situation.
Old Oct 29, 2001 | 12:14 PM
BOOSTD 7's Avatar
Persona non grata
An Audiomobile Evo 10" for SQ or Mass for SPL would be my choice ...
Old Oct 31, 2001 | 01:52 AM
psycheus's Avatar
Who makes that speaker? (EVO?) do you have a link for them?
Old Oct 31, 2001 | 07:22 AM
dnewman's Avatar
Audiomobile makes the EVO and MASS speakers. Just a warning about them. They sell great subwoofers, but they are very expensive. In my experience they don't offer a very good value compared to some of their competition. They also have an owner that seems hell bent on pissing on every potential customer by belittling them ( i should say attempting to belittle them) on car sound forums on the net. He also seems to attack any of his competitors without cause in most cases. Don't know if that will affect your speaker buying but it is something to consider.
Old Nov 1, 2001 | 07:54 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Kicker Solo-Baric the new square ones. A 10" sounds like 12" and requires less air than a traditional designed speaker.
Old Nov 3, 2001 | 12:37 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
I'd go with a 12" Boston Pro in the spare tire well. Thats what I'm planning on doing. These subs are awesome!!!! My best friend has two in the spare tire well of his MKIV Supra and they are INSANE hitting off the glass of the hatch. Thats what I'd do.
Old Nov 7, 2001 | 09:18 PM
Zoomspeed's Avatar
I been told that infinity perfects are good. how do they compare to these subs that you guys are mentioning?
Old Nov 7, 2001 | 11:07 PM
the_glass_man's Avatar
Will u do me a kindness?
I've heard good things about these as well. I might get one of these in the 10 or 12" variety
Old Nov 8, 2001 | 07:53 AM
dnewman's Avatar
The Perfects are nice but don't handle too much power. If you are considering a 10", check out the Titanic 1000 from www.partsexpress.com. If you are thinking about a 12" that will blow away the Perfects in every respect but looks, check out the Dayton DVC or AdireAudio Shiva available at www.partsexpress.com and www.adireaudio.com, respectively.
Old Nov 8, 2001 | 10:36 PM
Zoomspeed's Avatar
What sounds the best.
Pretty much what I'm looking for is a 10" Thats sounds nice and clear, since I normally don't want to rattle my trunk or windows. But I would like somethig that can pound if I want it to, for those times some guy thinks is 2 12" from radio shack can out pound me.
which one should I get? perferable something that doens't lighten my wallet to much.
Old Nov 9, 2001 | 06:53 AM
dnewman's Avatar
Blueprint 1001 or 1201 for $69 or $79.00 respectively.
www.blueprintdrivers.com
Give 'em a try, you will not be dissappointed.
Old Nov 9, 2001 | 01:47 PM
Zoomspeed's Avatar
Are these better then the infinity perfects? I was also considering a rockford HX2. Are the blueprints better then the HX2?
Thanks for any help.
Old Nov 9, 2001 | 01:56 PM
dnewman's Avatar
The blueprint 01 series would be close but not quite a match for the Perfects, but they are under half the money. Two of them would blow away the Infinity's. If you are considering the HX2, then the BP 03 series would be the way to go. They will lay the RFs to waste along with almost any other sub on the market.
Old Nov 9, 2001 | 10:41 PM
Zoomspeed's Avatar
Thanks, I'll look into the blueprints.
Any other suggestions?
*edit*
I just checked the website and they don't have the 03 in a 10" size It sounded pretty impressive from they're description too.
Any suggestions a 10" that sounds good but can blow away alot of other stuff?
Old Nov 10, 2001 | 08:47 AM
dnewman's Avatar
The Titanic 1000 from www.partsexpress.com is pretty nice. As well as the SB10 from www.stryke.com. I don't know of a real cheap 10" that has exceptional SPL capabilites. The two I mentioned have better SQ than a 10W6 from my experience and are cheaper. The SB10 from stryke is an exception woofer for SQ.
Old Nov 11, 2001 | 09:32 PM
Zoomspeed's Avatar
THanks for the input. I decided to go with the HX2 though becasue my friend can hook me up with one for $50.
Now I need to figure out what amp to get.
Old Nov 12, 2001 | 04:38 PM
Zoomspeed's Avatar
Well, looks like my friends hook-up has fallen through, so once again I am open to suggestions. Some of the audio shops in town have recommended audiobahn, eclipse, and soundstream. What do you guys think of those?
Old Nov 14, 2001 | 02:00 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Id go to Radio Shack and get ya one of those bad *** 10 or 12 inch realistics LOL jUST PLAYING
We sell Audiobahn at my store but there warranty really sucks. they wont let us do in store tradeouts. The speakers are pretty good, but I think they look better than they sound. Ive done a few Soundstream Mules before, they were Ok, but PRICEY as hell.
better thing to ask is what is your price range?
Old Nov 14, 2001 | 08:43 AM
Zoomspeed's Avatar
under $500 is my price range. Right now I'm thinking a 10 or 12" eclipse titanium series. What do you think of those?
Old Nov 14, 2001 | 10:21 AM
95R2-89TII Ground Zero's Avatar
Banned
I like the Eclipse titanium, but I can get the Infinit Kappa Perfect for next to nothing and it sounds great. I think thats what I'll end up going with.
