Rotary Drag Racing The place to post your racing stories and info
What size to get on Mickey Thomson slicks?
Old Oct 15, 2001 | 10:24 AM
RecKleSs's Avatar
Adrenaline
Question What size to get on Mickey Thomson slicks?
I want to purchase some tires and I don't know if there are any clearance problems with these tires. I know that there are a lot of people using these tires on the FD, but what size should I get? I will be using the stock rims and want to get the Mickey Thomson ET tires. I'm also using the H&R Springs, which lowers the car to 1.25"
Also, what are your feelings towards using a Line Loc?
Old Oct 15, 2001 | 01:19 PM
GsrSol's Avatar
Z06 powered FD
I don't think the ET DRAG comes in a 16" .
The ET STREET comes in a 26x10.5x16 which I think will fit the stock rims.
Old Oct 15, 2001 | 02:58 PM
RecKleSs's Avatar
Adrenaline
Oops, I guess I messed up on my post. I want to get the Mickey Thomson ET Street tires. Thanks for your help GsrSol.
Old Apr 8, 2006 | 03:45 PM
LUPE's Avatar
I run a 26/11.5/15 ET Street.
Old Apr 8, 2006 | 10:06 PM
the_saint's Avatar
on what type of wheel? Pix?
Old Apr 8, 2006 | 11:06 PM
LUPE's Avatar
Search my name and you'll see my pics.
Old Apr 9, 2006 | 02:14 PM
Busted7's Avatar
Will work for horsepower
the 26 10.5 ets fit good on the wheels and have no clearance problems. the 11.5s might be a little large?
Old Apr 9, 2006 | 05:58 PM
Swolbynos's Avatar
Newb
i have some 26x11.5x16 ET Streets. they dont rub when the car is int the air
hopefully i will know if they rub while driving by next weekend
Old Apr 13, 2006 | 10:03 PM
ErnieT's Avatar
Living life 9 seconds at a time
If you run the 11.5's you'll need to roll the fenders.
Old Apr 13, 2006 | 11:41 PM
Swolbynos's Avatar
Newb
how much, as in could i get by with ghetto rolling it until i can afford to get them rolled by a pro.
Old Apr 17, 2006 | 07:34 PM
As per Ari, you want to run the MT et's in 26x10.5x16.
Also, spoke to Chris Ott (also over at www.rx7.com) today and he recommended the 4.3 final drive for anybody using the MTs in that size.....the larger rolling diameter effectively makes your final drive ratio numerically lower, which is *not* a good thing......
Old Apr 17, 2006 | 10:05 PM
Swolbynos's Avatar
Newb
yep, i know i should have gotten the 10.5, but $100 for both of these with one pass on them was a pretty good deal.
Old Apr 19, 2006 | 06:17 PM
1wide7's Avatar
the only thing that changes the final drive ratio is tire height
so it does not matter if you get the 10.5 or the 11.5s the 11.5 obviousley give you better traction since they are wider but most events specify that you need a 10.5 tire
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
