techline ceramic coatings
Old Jan 8, 2004 | 08:08 PM
The_7's Avatar
Registered Piston Eater
techline sells a thermal barrier do it yourself ceramic coating in 3 oz bottles for $30 each. how much do you think it would take to adequately coat all 3 faces of 2 12A rotors?
edit: the coating is water based and can be cured in a normal oven
Old Jan 8, 2004 | 08:29 PM
The_7's Avatar
http://www.techlinecoatings.com/Engine.htm
Old Jan 8, 2004 | 08:34 PM
wwilliam54's Avatar
it WILL run
awesome
Old Jan 8, 2004 | 09:04 PM
Rx7carl's Avatar
Airflow is my life
I think you need to call them and get an estimate of sq in of coverage per bottle or per oz. Then you can calculate what you'll need.
Old Jan 8, 2004 | 09:18 PM
1stgen4life's Avatar
Leaking oil like crazy!
I'll second what Carl said.
