Car won't start......
Old Jan 5, 2004 | 11:24 PM
Eternal_Gamer's Avatar
My car won't start. I am still getting spark. I am still getting gas. I checked both. Now I am stuck. Any suggestions. I hear a "EEEEEEEEE'' sound when I try to start my car. It rotates but wont turn.
Old Jan 5, 2004 | 11:26 PM
truespin88's Avatar
truespin, not tirespin
If it just sounds like the starter is just spinning itself without engaging the engine, give it some love with a hammer (not too much love, mind you) and then try it. If it doesn't work then, check/charge your battery and try again.
If it sounds like the engine is spinning but there's no compression, you're probably flooded, and should go through the typical unflooding procedure, which can be found by searching.
Old Jan 5, 2004 | 11:27 PM
what rotates but doesnt turn? need more details
Old Jan 5, 2004 | 11:43 PM
razorback's Avatar
You've Been Punk'd
http://www.rx7.com/tech/unflood-fc.html
Old Jan 6, 2004 | 12:39 AM
oregano's Avatar
"EEEEEEEEEE" ? alternator belt slipping, starter solenoid not engaging, electric buzzer. i dunno.
eddierotary
Aug 16, 2015 04:12 PM
