Need an AFM for my 85 gsl-se
hey today i was messin around with the GSL-SE and i found out the air flow meter was bad, i stuck the one from my 86 on it and it started, and ran instead of dying, but it runs like **** lol, i need an afm thats the right size for it, if anyone has a spare let me know how much you want for it. thanks
GSL-SE Airflow meter
I've got one I can let go. Even got the wiring harness that runs to the brain for it too.
But, as to price, I'd rather swap for some '89-91 2nd gen parts I need.
PM me.
PM me.
Just to let you know, that the 2nd gen AFM are not compatible with the GSL-SE (wiring issue). The 2nd gen AFM has a two door setup where are the GSL-SE only has a single door.
That's why the car ran like sh*t. Gotta test your's out with another GSL-SE AFM swap.
Your's might be fine. Just make sure your door in the AFM moves freely.
well with the stock AFM it would start and then just die, i put the 86-88 AFM on and it started and runs fine, i still need the AFM but i also need one working injector, and the fuel rail with the bolts. let me know if you got those also, what parts you need, i dont have 89-91 parts
i have 86-88 parts, let me know
