ECU ground causing problems?
Old Jan 5, 2004 | 01:07 PM
crackavelli's Avatar
I had a problem with my 1991 convertible occasionally stumbling (I would lose all power for about one second) in left corners. I thought the problem might be a loose ground connection to the ECU, so I ran new ground wires to the ECU.
I haven't had the stumbling problem since I ran the new wires, however now the car seems to lose a lot of power above 6000 rpm. Sometimes the power will kind of pulsate at the higher rpms.
Could this be because the new grounds I ran don't have good connection?
Any help would be appreciated.
Old Jan 5, 2004 | 05:01 PM
Icemark's Avatar
Probably a clogged or dirty fuel tank filter. Clean or replace the fuel tank filter. Pretty common, you may wish to use the search function next time found in the upper right hand corner of the page.
I am assuming that you are not loosing electrical power, but rather engine power?
Old Jan 5, 2004 | 05:03 PM
Correct, I am losing only engine power. The electrical power seems fine.
Old Jan 5, 2004 | 05:04 PM
Icemark's Avatar
clogged fuel tank filter (not the fuel filter, but it is the fuel tank filter).
Old Jan 5, 2004 | 05:17 PM
Rpeck's Avatar
What R U thinking self?
Ya, the one in the TANK!
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
