Its getn better, but sitll need help.
Old Dec 30, 2003 | 05:47 PM
BigJim's Avatar
trainwreck
Ok got my new exhaust on and put everyhting back together. Start up the car she revs up to like 3500, that seems alot high for the normal rev up then idle down. Then i notice, it gets to like 2500 rpm then just shuts down. If i hold the gas pedal itl stay runnin and i notice a slight miss, and the idle fluctuates(grand, another vac leak). Well i adjusted the tps and got it to run at about 1500 rpm but the idle fluctuates and i cant keep it running below 1500 rpm. As soon as it gets below 1500 rpm it just shuts off. Ive used the carb cleaner method to track down leaks and im not finding anything. Anyone have any ideas why it just shuts down when the rpms get to about 1500?
Old Dec 30, 2003 | 06:27 PM
Ghostrider's Avatar
ne voccum leaks maybe???
Old Dec 30, 2003 | 06:30 PM
nlc1179's Avatar
that sounds like how mine was acting when the front rotor had low compression on my -se
Old Dec 30, 2003 | 06:32 PM
BigJim's Avatar
trainwreck
I kno theres a vac leak causing hte idle to flucuate, but ive never heard of a vac leak actually killing the engine like that. Ill check my compression.
Old Dec 30, 2003 | 06:35 PM
BigJim's Avatar
trainwreck
Could a intake leak between parts cause it to do that, i got all the surfaces realy clean before i put on new gaskets, but i dunno if it did the trick.
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
pfsantos
Sep 30, 2015 01:29 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
