WTF did i break HELP NEEDED ASAP
Old Dec 29, 2003 | 09:10 PM
Gregs's Avatar
WTF did i break
i was pulling that hose off and broke the little plastic thing off
i think it has to do with the oil injection
please help me, i want to get the car running tonight!
-greg
BTW this is a 79 engine
Old Dec 29, 2003 | 09:15 PM
slashdawg00110's Avatar
RTFFAQ
I can't tell what you're pointing at. The bolt? Anyway, good luck.
offtopic: I looked at your cardomain site. Where did you get the cat replacement pipe?
Old Dec 29, 2003 | 09:19 PM
Gregs's Avatar
the thing behind the bolt!
i got my pipe from the good ole moderator here (props to rx7carl )
u can get em at www.testpipe.com
-greg
Old Dec 29, 2003 | 09:39 PM
RTFFAQ
I thought maybe it was behind the bolt. Can you get a better pic? I'm not familiar with the 79 carb, but it's not much different from the one on my 83. I don't think. You got a haynes manual? Based on the pic on page 99, it looks like you should be able to cap both ends for now with out a problem. It's just part of the emissions system piping.
That testpipe.com web site doesn't work for me.
Old Dec 29, 2003 | 10:54 PM
Gregs's Avatar
im 99 percent sure thats the site, it looks like its under construction...
-greg
Old Dec 30, 2003 | 12:19 AM
rxtasy3's Avatar
when I ran the stock setup, I just blocked everything off, but I think it may be the PCV valve.
Old Dec 30, 2003 | 01:31 AM
Gregs's Avatar
pcv?
Old Dec 30, 2003 | 02:01 AM
Directfreak's Avatar
I am a Jeeper Now.
Flux Capacitor.
Old Dec 30, 2003 | 02:02 AM
Gregs's Avatar
lol directfreak...
Old Dec 30, 2003 | 03:37 AM
jayroc's Avatar
Altitude compensator?
Old Dec 30, 2003 | 03:44 AM
jayroc's Avatar
I had one break on my SA i used to have. You can use some rubber cement and glue it back together again. It'll unbolt from the carb.
Old Dec 30, 2003 | 06:10 AM
Rx7carl's Avatar
Airflow is my life
Greg, you shoulda removed the bolt. But yes indeed its the PCV hiding behind it. Glue it back on, or block it and use the crank vent system in the emissions tutorial.
Hehe, my pipe is famous.
Yea testpipe.com is out of business. Look on ebay, theres some joint selling test pipes for various cars.
Old Dec 30, 2003 | 06:18 AM
Jeff20B's Avatar
Lapping = Fapping
Keep an eye on your oil filler tube.
Old Dec 30, 2003 | 06:31 AM
Rx7carl's Avatar
Airflow is my life
Re: WTF did i break HELP NEEDED ASAP
Originally posted by Gregs
Its a bolt.
Old Dec 30, 2003 | 08:12 AM
RTFFAQ
I'm looking through my Haynes manual and don't see a PCV anywhere. Just for my education, is it called something else?
Old Dec 30, 2003 | 08:57 AM
Metallic_rock's Avatar
Ride 'n Style
You shoulda seen his face last night when he broke it!!! It looked exactly like (he was using my car as an example for doing the tubing for his) it was like 20 degrees outside when we were working on it. Every rubber tube was hard. (yes, they were new)
So, long story short, he should just be able to put some epoxy or something in there to plug the PCV and then put a cap over the other hose?
For those that don't know, we were following the emissions removal tutorial that Rx7Carl and Pratch wrote and posted on the Mazspeed site.
Oh, and he did remove that bolt...
Old Dec 30, 2003 | 09:37 AM
Rx7carl's Avatar
Airflow is my life
Nope, called a PCV valve slash. LOL, you shoulda got a pic of Greg. Yea, just plug it with epoxy. Cap what other hose?
A little late now. Tell him not to quit his day job.
Old Dec 30, 2003 | 10:42 AM
Ride 'n Style
Picture taking was not exactly on any of our minds... it was so damned cold, we just wanted to get the thing put together!! I didn't even stick around too long. Got the electrical stuff and the hoses connected and I hopped back in my nice warm car and went home!!
Old Dec 30, 2003 | 02:57 PM
RTFFAQ
Ok, I must need reading glasses. I'll peruse the manual again and look for the PCV valve in there.
Old Dec 30, 2003 | 06:12 PM
Gregs's Avatar
i ended up capping both of those off, im gonna get the car running tonight and see ow well it runs...
-greg
Old Dec 30, 2003 | 06:29 PM
wwilliam54's Avatar
it WILL run
i have a 79 intake
that plastic thing is just a check valve for the brakes IIRC
or at least thats what it is now
