Airpump bad! Or good?
Old Dec 28, 2003 | 01:03 AM
Looking under the hood of my GSL i noted the previous owner had beggun removing some of the emissions controls. all vaccum lines except the idle compensator had been plugged off.
i also noticed that th airpump had been removed too.
Is this gengerally a good hting? or would the car run better if i found one and put it back?
Old Dec 28, 2003 | 01:08 AM
coldy13's Avatar
Yeah, shutup kid.
Check to see if there is a catalytic converter still on the car. If there is, then you need the airpump or else the cat will become clogged(or just replace the cat with a presilencer or straight pipe). If there's no cat on the car, then it's good that it was removed.
Old Dec 28, 2003 | 02:54 AM
ok
Iff thers a cat still on the car,
is this the same as the thermal reactor?
what would be affected by a clogged cat?
Old Dec 28, 2003 | 04:58 AM
Jeff20B's Avatar
Lapping = Fapping
The air pump must be used with a thermal reactor. The guy with the yellow car in his avatar will tell you more.
Old Dec 28, 2003 | 08:58 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Well you said you have a GSL, so you don't have a thermal reactor on your car. A cat performs the same duties of a TR, but in a different way. Both need fresh air to burn off the excess polutants in the exhaust and both will be damaged if the air pump is removed. In the case of a cat, it can become plugged, restricting exahust flow and reducing power.
If however your cat was removed along with the airpump then you'll be just fine without it.
Old Dec 28, 2003 | 09:23 AM
O 16581 72452 5's Avatar
The infamous number guy!
Cody should chime in soon about the effects of a clogged cat.
Old Dec 28, 2003 | 03:02 PM
g prime's Avatar
I would assume a clogged cat would totally kill you preformance and gas milage, but I don't want to *** u me anything. So anybody else?
Old Dec 28, 2003 | 07:42 PM
coldy13's Avatar
Yeah, shutup kid.
I love the effects of a clogged cat. A clogged car gave me a RX-7 in great condition for $500 because the owner thought the engine was blown
A semi-clogged cat will make the car preform terribly. If it's completely clogged like mine was, the car won't even run.
Old Dec 28, 2003 | 07:44 PM
wwilliam54's Avatar
it WILL run
I dont know much about it
get a test pipe and remove the air pump
if you dont have emissions
Old Dec 29, 2003 | 12:55 PM
g prime's Avatar
Dam, 500 for a good RX7 and all it was, was a clogged cat. That is a great deal.
Old Dec 29, 2003 | 01:02 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Old Dec 29, 2003 | 05:33 PM
wwilliam54's Avatar
it WILL run
Originally posted by Wankelguy
I like your yellow car better
Old Dec 29, 2003 | 06:32 PM
Wankelguy's Avatar
Thanks. It's the box art from a Nichimo 1/25 scale plastic model kit of the Savannah GT (RX3 to us).
I actually have a '72 RX3, but it's red.
Old Dec 29, 2003 | 06:50 PM
inittab's Avatar
I read your email
Hello? We need to see P I C T U R E S of that bad boy!
Old Dec 29, 2003 | 06:58 PM
wwilliam54's Avatar
it WILL run
I concour
Old Dec 29, 2003 | 11:20 PM
Wankelguy's Avatar
Oh come now, it's more fun this way, don't you think?
Have you no sense of mystery?
Here's a little teaser...
Old Dec 30, 2003 | 04:23 AM
hehe back on topic
heeh this threads all about me? remember?
Old Dec 30, 2003 | 06:00 AM
inittab's Avatar
I read your email
Sorry 'bout that Cap'n, we done highjacked your thread.
Anyway, back to the air pump. What's the verdict on the catalytic converter? Is it still on your car?
Old Dec 30, 2003 | 11:03 AM
I cut my airpump over a month ago on my 1980. I installed a 2nd gen alternator with a dual belt pulley. My car had been backfiring like a **** and then it stopped when I cut the airpump...well...except for that uncle buck backfire this morning. I figured my original cat was probably blown from the months of me driving it backfiring. Although, I would like to get a *cough testpipe cough*.
Old Dec 30, 2003 | 11:46 AM
Uh
What is a test pipe?
Old Dec 30, 2003 | 11:53 AM
it seems to have mystical powers.
although I have also heard a broom handle in the cat might do the same exact thing...
Old Dec 30, 2003 | 12:00 PM
anthrax's Avatar
Heck Yes!
Eh just put on a RB header and exhaust and dump the air pump and enjoy the extra HP
Old Dec 30, 2003 | 12:05 PM
And here is another n00b question: wahts the alternator do for power output? I thought it just ran the car's electrical when the engine was running?
and no RB exhaust at the moment i am a poor student and a fan of macGuyver
Old Dec 30, 2003 | 12:07 PM
Ah
Aha.. so i thread a pipe or brroom stick up the exhaust and feel around for... what?
I had also heard that if things were running good you shouldn't be able to put your hand over the back of the tail pipe because of the air pressure...
i could quite easily, if not for the heat :P
Old Dec 30, 2003 | 12:42 PM
well, what I have *heard* is that you disconnect the cat and then shove a broom handle or something similar in it and break up all the stuff in it and pour it out. It hollows out the cat. It's not like I know first hand or anything...*cough*
