how do u attach a front spoiler
Old Dec 24, 2003 | 11:19 AM
redlinein_rx7s's Avatar
how do u attach the front spoiler i was told screws and adhesive?
Old Dec 24, 2003 | 11:24 AM
BigJim's Avatar
trainwreck
oh thank god. I thought u actaully meant a front spoiler. As for attaching an air dam, ivbe heard screws and adhesive. The gt500/350's couldnt pull off a front spoiler so im doubting a 7 could.
Old Dec 24, 2003 | 11:48 AM
MarkPerez's Avatar
Tennis, anyone
Well the ford front 'chin' spoilers used on the trans-am
boss mustangs and the cars sold to the average joe-bob
were in the trunks for the owners to install. 4 screws hold on the plastic 'chin'spoilers.. as for an airdam for a rx7 it depends on who made the part. My mariah front airdam is attached with 2 large bolts,nylocks. but any fibre-glass front airdam will use bolts and screws. don't even think of using a glue.
Old Dec 24, 2003 | 12:39 PM
Cody's Avatar
SKELETOR!
I think mine is on with rivets.
Old Dec 24, 2003 | 01:05 PM
Sk8r_dude's Avatar
Zoom - Zoom...
urethane
Old Dec 24, 2003 | 01:20 PM
urethane?
Old Dec 24, 2003 | 01:34 PM
wwilliam54's Avatar
it WILL run
if you use screws some 3m double sided tape (great stuff) in-between the screws would help alot
Old Dec 24, 2003 | 01:45 PM
thnx
Old Dec 24, 2003 | 01:49 PM
wwilliam54's Avatar
it WILL run
pics after you install it ?
Old Dec 24, 2003 | 01:51 PM
yea 4 sure but it wont be 4 a while because its geting repainted and new int all rust gone evrything
Old Dec 24, 2003 | 03:20 PM
RX-187's Avatar
live fast. die fun.
Where can I get that?
Old Dec 24, 2003 | 03:21 PM
were can u get wat
Old Dec 24, 2003 | 03:25 PM
RX-187's Avatar
live fast. die fun.
the front air dam
Old Dec 24, 2003 | 03:32 PM
mazdatrix.com or used
Old Dec 24, 2003 | 04:25 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
From your image that looks like a Mazda Factory 'performance shop' FAD which is pretty hard to find these days.
Since it's urethane, you can use flathead screws on the inside mounting points. I also ended up using some kydex sheet and pop rivets to allow for some 'give' (i.e., release), should the airdam come in contact with something truly solid.
Make sure that it's secure, however - you don't want that thing to go solo when you're cruising down the freeway at 75mph. It gets a LOT of force applied against it, particularly so since it's block shaped at the front. You should notice markedly improved front downforce with it installed, and no more high speed steering lightness. One of the big improvements that come with installation of ANY front airdam on a 1st Gen.
Old Dec 24, 2003 | 05:32 PM
ok thnx no adhesive then?
Old Dec 25, 2003 | 04:15 AM
MarkPerez's Avatar
Tennis, anyone
I also use rubber 'washers' or grommets for 'shock' mounting the frontend. remember fibre glass is ridgid
and needs some 'give' so it won't crack as fast
