Twin turbo setup!!!!
Old Dec 24, 2003 | 01:09 AM
Rx-7pl's Avatar
Question Twin turbo setup!!!!
Is there aftermarket twinturbo setup availible for fds3?
If so where? Is it better than single turbo?
Old Dec 24, 2003 | 01:53 AM
radiantRX-7's Avatar
Yes there is go to rx-7 store.net I will say it is better then a single,but expect to pay well over 5 large for it.
Old Dec 24, 2003 | 08:53 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Why would you say it's "better"... Do you have the kit? Any experience installing or maintaining it? How does the power curve compare to a single setup? At what RPM do you reach full boost? Any dyno numbers? Any fitment issues?
And expect to pay way more than that if you plan on installing mods to SUPPORT an aftermarket turbo kit.
Good day.
Old Dec 24, 2003 | 10:54 AM
r71's Avatar
r71
Damn~
Old Dec 24, 2003 | 11:08 AM
racer1's Avatar
flying apex seal
I would go with a decent single. Much more sipmle setup
Old Dec 24, 2003 | 11:12 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
It depends on what you want as a set up. Do a search on BNR in this forum and look around the single turbo forum to see what fits you best.
Old Dec 24, 2003 | 11:13 AM
Zoomspeed's Avatar
The kit is also non-seq. I dont really see the benefit of it over a single turbo.
Old Dec 24, 2003 | 11:14 AM
Flybye's Avatar
It's never fast enough...
I wish someone wold create a better SEQUENTIAL system. I don't know what aftermarket crackpipe the Mazda Engineers were using, but why they didn't decide to go with a much simpler system is beyond me.
Old Dec 24, 2003 | 11:22 AM
Yes it is for sale.
werd
Old Dec 24, 2003 | 11:34 AM
Flybye's Avatar
For those of you that haven't seen the MKIV sequential system, prepare to be astonished.....
Yep, that's it boys, and their damn turbos can go over 20psi without even sweating. Now I know why the Supra's cost nearly $50k. They had to cover the cost's of R&D. At least they did their damn job
Old Dec 24, 2003 | 11:43 AM
Yes it is for sale.
But its not a rotary.
Old Dec 24, 2003 | 11:44 AM
Flybye's Avatar
I was talking about the turbo sequential system, NOT the engine
Let me know when you learn how to read
Old Dec 24, 2003 | 11:47 AM
dubulup's Avatar
development
The RX-7 was the first seq system, so give the engineers a break for being the first to mass produce it.
Old Dec 24, 2003 | 11:52 AM
Yes it is for sale.
But its attached to a piston engine. Are you suggesting that someone should look into installing a set of Supra turbos onto a rotary?
I can read fine, I am just stating the obvious for discussion purposes. Unless that is your Toyota diagram was ment for more instrumental purposes?
Old Dec 24, 2003 | 11:57 AM
dubulup's Avatar
development
I think he was just saying it is simple compared to the hidious vac diagram we all know and love.
Old Dec 24, 2003 | 12:07 PM
Flybye's Avatar
But its attached to a piston engine. Are you suggesting that someone should look....
I don't know what you are talking about. I don't see a piston engine in the center of that pic....
That actually wouldn't be a bad idea, but their turbos and manifold would never bolt up to our engine, and the cost of having a custom manifold created just for those turbos wouldn't make any sense. You would be better off just buying upgraded twins, but we would still have the hassle of dealing with our vacuum system.
Even if we were to somehow adopt this sequential system, we would still need to figure out a way to control it....
It actually wouldn't be a bad idea for someone to start producing custom exhaust manifolds with high-flow turbos, and some type of small ECU to control the sequential operation. An ecu that can get RPM and boost readings in order to have it as efficient as possible. I'd love to see how well these little turbos would flow if they were connected to a tubular manifold. The Supra guys can use em up around 500hp, so they must be good for something.
Old Dec 24, 2003 | 12:12 PM
dubulup's Avatar
development
slick
Old Dec 24, 2003 | 12:14 PM
Yes it is for sale.
haha
A custom exhaust manifold would the the place to start. Let not cast it but actually make one out of welded steel and heat treat it before instalation.
The key would be to get the exhaust gas control valve to for the second turbo to open and shut on comand at a specified RPM. This would control ehaust flow and direct it into the first below this RPM and then divert it above.
Old Dec 24, 2003 | 12:22 PM
Flybye's Avatar
Nope.
As far as I know, the Porsche 959 had the first sequential turbo system back in the 80s, and it WAS mass produced, just not in this country.
Old Dec 24, 2003 | 12:24 PM
Yes it is for sale.
Not to nit pick but the 959 was federalized this year.
Old Dec 24, 2003 | 02:22 PM
artguy's Avatar
WTB** Very Low Miles 94-95
you mean it has low end torque...
lol
Old Dec 24, 2003 | 02:30 PM
Yes it is for sale.
Actually I am going to ask around next month to see if I can get hold of a set of Supra twins in the Houston area.
I have been thinking about this all morning and as long as they fit in the limited space, the rest can be fabricated.
A benefit to owning an engineering firm is access to the fab facilities to make this and other ideas possible.
Old Dec 24, 2003 | 02:32 PM
Sesshoumaru's Avatar
Tenseiga
i think he was talking about the larger exhaust pulsations from the rotary.
i think not having a constant pluse would hurt that "bleed" type of system.
i think that's why mazda ended up with the pre spool system.
torque might have a role to play also. I don't konw.
Mahjik's Avatar
Mr. Links
Yea, it only took a year or two (or 15) for that to happen.
Old Dec 24, 2003 | 03:54 PM
Flybye's Avatar
....A benefit to owning an engineering firm is access to the fab facilities to make this and other ideas possible.
Can I be your friend?
Flybye <<< Engineering major
