Help
Old Dec 20, 2003 | 03:10 PM
Rx-7pl's Avatar
Help
and i'm gonna put downpipe ,pulleys, new clutch stage 3 and lightweight flywheel?
how many hp?
how fast 1/4 mile?
is light weight flywheel going to help me accelerate?
Old Dec 20, 2003 | 03:11 PM
XSTransAm's Avatar
Ee / Cpe
you bought stuff that you dont know what it does?
Old Dec 20, 2003 | 04:35 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
He's a newbie.. I was there once..
Hey, you need to think about it more before just thinking that thats going to make ton of power..
I recommend reliablity mods first.. Down pipe first.. than get a boost gauge.. upgraded radiator, boost controller, cat back..
that should give you slightly more power.. after that, any other mods, you might want to consider upgraded ECU.. and keep your boost DOWN until you have proper ecu.. Still keep your boost down..
Pulleys usually mean taking out airpump.. which means you should go with hi flow car or midpipe.. which means you will have boost spike..
Do a search.. ton of info on this forum.. take tomorrow off.. and spend 8 hours reading old threads.. you will learn ton of stuff..
Good luck!
Old Dec 20, 2003 | 10:15 PM
0110-M-P's Avatar
Too Many Projects
^what he said. Don't be out there for just power. If you do that you won't like having to spend 3000 dollars to rebuild your engine. Spend the fraction of that 3000 dollars and make your motor last (radiator, ast, ECU if you upgrade to a midpipe and such)
M-P
