what to do with my engine
Old Oct 10, 2001 | 07:04 PM
Rotorific's Avatar
I dont know a damn thing
I just recently took a turbo2 block out of an 87 gxl except that the car was in NA form i mean there was nothing turbo related. SO my question is if there is a way to check for what compression rotors are in the block or is it not possible to transpose them. Wouldnt the car be slower than a constipated dog taking a ****? Eh i give up Ive just realized this weekend that now i need the T2 drivetrain conversion on my 86 base. Argh any adive is welcome. - Gabe
Old Oct 11, 2001 | 07:27 PM
tesla042's Avatar
Why do you think it's a t2 block? I dunno about the rotors, but if it is a t2 block, it's a 4-port, not a 6 port....therefore, it would NOT have any aux ports or actuators..
mm...dunno any good way to test the actual compression ratio....hmm... Maybe the flywheel is different?
-Tesla
Old Oct 14, 2001 | 02:32 AM
Rotorific's Avatar
The flywheel is bigger and flat as an NA flywheel has the raised areas on it . I need to know if i can switch out a T2 flywheel and repace it with an NA flywheel so my transmission will fit on. Can it directly be swapped or is there some work? - GAbe
Old Oct 15, 2001 | 08:37 AM
direct fit, check the weight differences between the two
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
