Power FC AVC-R or PFC BOOST CONTROL KIT ?
Old Oct 9, 2001 | 11:54 PM
vosko's Avatar
Just Call Me Terminator!
i'm going T04S just wondering which would be better. i heard they are basically the same thing. i would rather have less clutter in my interior and have the boost control kit but i want to know if either will perform better?
Old Oct 10, 2001 | 03:46 AM
maxcooper's Avatar
WWFSMD
If you can find a boost control kit, buy it. It seems to have been discontinued. The advantages over the AVC-R are the ability to run more boost than the stock MAP sensor can read (about 17 psi), potentially easier hookup, and less interior clutter.
Otherwise, you can get an AVC-R for $399 shipped right now from titanmotorsports.com. Look under "Group Buys".
-Max
Old Oct 10, 2001 | 10:22 AM
Bacon's Avatar
IRS 4 Life
ok, i thought u couldnt run over 17 with the stock map sensor,with the pfc is this b/c it cant controll boost, or it wont dump in enough fuel..i remember the boost contoll kit comin with a upgraded map sensor, is their any way to beat havin to try to loacte the kit? aka buy a diff brand map sensor and do a little creative wiring?
i have a profec b and when i get my single im gonna be runnin 20-22psi, would i just be better off gettin haltec, or can the pfc handle that psi....im confused
Old Oct 10, 2001 | 11:25 AM
Jason's Avatar
The one
The Power FC reads boost 2 lbs lower than manifold pressure.
Thus you can run 19lbs of boost and the Power FC is reading 17lbs. Once you go over that its reading the last cell of lines on the map. At least thats what its doing on mine.
Jason
www.rx7store.net
Old Oct 10, 2001 | 01:34 PM
The PFC can control just about any MAP sensor all you have to do is change the PIM voltages I belive.
What I really don't know is how the PFC controls higher boost.
I bet that can be changed with the Power Excel software.
Old Oct 10, 2001 | 01:54 PM
suganuma's Avatar
no
jason,
what altitude are you at.....sounds like youre about 3-4k ASL
if thats right then the gauge is reading the pressure the turbos are producing while the pfc is measuring absolute pressure - the pressure that the manifold is seeing after compensating for loss for altitude.
try turning the pfc power on with the engine not running. when doing this my friend in denver (6000 ft asl) sees a negative vacuum and i myself see about -175mmHg and im at 7250 ft asl.
the -175 equals out to about 3.5 psi which is the difference in the gauge and the pfc readings i get, but is also the difference in atmosperic pressure from here to sea level.
check it out, let me know what you find.....same for the rest of you.
thanks
Old Oct 10, 2001 | 02:16 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
Nic,
I seen ~ -145 mm Hg when my PFC is on but the car is not running, This worked out to be ~ 2.8 PSI which is close to the difference in boost #'s that i see on my gauge and on the PFC
Old Oct 12, 2001 | 07:06 PM
vosko's Avatar
i contacted xs. what they said was i can buy a map sensor from them and send them my pfc then i can run up to 2 bar or boost. at first i thought boost above 1.2 bar wasn't a concern but now it is. i have to see how i like my car at 1.2bar and if i want to go through the hassle to go above 1.2bar either boost control kit(if i can get one), xs solution, or a different ems (haltech, microtech)
Old Oct 15, 2001 | 07:58 PM
vosko's Avatar
Smile
i bit the bullet and ordered a pfc boost control kit from srx7.com. i will be able to run how much boost i want 22psi
Old Oct 15, 2001 | 11:39 PM
RX-7 Pilot's Avatar
How much was the kit??
Old Oct 16, 2001 | 01:33 PM
vosko's Avatar
$400...
Old Oct 18, 2001 | 01:10 PM
Bacon's Avatar
IRS 4 Life
just to proove vosko right
heres a e-mail from eric hsu
Len,
If you want to run more than 17 lbs with the Power FC, there are several ways to do it. One way is to purchase the Boost Control Kit. By using the BCC, this will give you the ability to run up to 29.4 lbs, but not the capacity. What I mean is that although the fuel injection's MAP sensor can read up to 29.4 lbs., the maps inside of the Power FC only support up to 20lbs. You will still need to visit a Power Excel shop with the software to change the maps to read up to 29.4 lbs. At the moment, only XS Engineering has the software as they have been trained directly by our Japanese engineers. Other Power Excel shops will have access to the software sometime next year. The other way is to take your car to a Power Excel shop (with the software once again) and they can install the Apex 3bar MAP sensor directly into your engine harness. The third way to do it is to have a Power Excel shop make a custom program using any MAP sensor they offer. This could be a GM, Motec 6bar, Toyota, etc.
Contact a Power Excel shop if you want to purchase a BCC. We do not sell direct to the public.
The Haltech is a great system, but it's a little behind as far as performance capabilities. If you're into tuning your engine yourself, you want data logging capabilities, you don't mind tearing your factory engine harness apart, and you don't mind not being able to put the car back to stock without buying a new factory engine harness, then the Haltech is for you. If you don't mind paying a quality shop for proper tuning and installation (a whole 5 minutes), then the Power FC is for you.
Good Luck,
Eric Hsu
Chief Engineer
Apex Integration, Inc.
Old Oct 20, 2001 | 02:56 PM
vosko's Avatar
your da MAN !
Old Nov 3, 2001 | 08:27 AM
zkeller's Avatar
Does the map sensor mount into the stock mounting bracket?
Old Nov 3, 2001 | 10:53 AM
vosko's Avatar
i'll find out when my car gets put back together
cristoDathird
28
May 30, 2019 08:47 PM
