Any reason not to do this??
Old Nov 29, 2003 | 02:58 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
Using the stock primary rail, attach 6AN fuel line to the rail using the existing barb, and using a clamp vs, drilling and tapping the ends for 6an fittings.
Im getting close to finishing my swap and money is getting tight.
I will be using the stock 550 cc injectors.
Old Nov 30, 2003 | 12:18 PM
guess not...
Old Nov 30, 2003 | 03:12 PM
Trav's Avatar
I would think you'd be okay. Just be sure you're clamped good, etc. Might keep an eye on it for awhile. Barb/clamp setup is used elsewhere in the system, so should be okay.
Put it this way though, I would personally be okay doing it, but I would also view it as a temporary solution until i figured out how to (or saved the money for) converting it to AN fittings etc.
Old Dec 1, 2003 | 04:35 PM
yeh, I would eventually convert it, but the stock system is clamps, so it shouldnt matter.
maybe ill put a little sealer on there or something.
Old Dec 1, 2003 | 04:49 PM
frode's Avatar
And please keep a fire extinguisher in the car when hacking on the fuel system
Old Dec 1, 2003 | 07:01 PM
setzep's Avatar
That's what I have on my car on the rails, barbs.
renjiv2
57
Jan 25, 2024 03:34 AM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
