Sponsored by: CARiD
what happened to my rx7
Old Nov 29, 2003 | 12:52 AM
daegg420's Avatar
i was leaving work tonight and my 87 n/a 5 speed did something odd. as i took off i got to about 4000 rpm and after my 3800 stumble my car just took off i had to turn the car off when it hit 8000 rpm, it happened twice has this ever happened to anyone
Old Nov 29, 2003 | 03:37 AM
wwilliam54's Avatar
it WILL run
the throttle cable is probly sticking
Old Nov 30, 2003 | 05:04 AM
black_sunshine's Avatar
A little late, but I just remembered about a similar problem I had:
If it has cruise control, they can fail sometimes. The cc in my 88 GTU failed; if I was cruising and had the cc enabled (but not set), it would randomly give more/less throttle. And if I turned it on, it would just give full throttle and keep accelerating. If you've got cruise, turn it off or unplug it and see if it makes a difference. As for how to fix it, I'd assume that if you resoldered the cruise-control unit, it would fix it; dunno, never tried that. If not, then yeah, check your throttle linkages and stuff.
Old Dec 4, 2003 | 06:26 PM
RE13REW's Avatar
i have that happen too on cruise control... check the cruise control system
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
MazdaAspec
Sep 9, 2015 02:04 PM
armans
Aug 15, 2015 09:08 PM
86glxNA
Aug 15, 2015 01:45 PM
