momo wheel install help needed.
Old Nov 28, 2003 | 06:30 PM
fd3virgin's Avatar
what do i do with the connectors seen here. do i remove the clock spring to get the connectors out of the way b/c they just don't disconnect. tia kevin
Old Nov 28, 2003 | 06:34 PM
fd3virgin's Avatar
where do you hook up the horn? thanks.
Old Nov 28, 2003 | 06:38 PM
rockshox's Avatar
if you want to keep the horn you have to keep the clockspring and enlarge the hole in the new steering wheel hub to allow the clockspring connectors to fit through.
otherwise remove the steering column cover and there are 3 really obvious screws that hold the clockspring on.
the black ground wire connects to the hub and i think i remember it being the orange plug is the horn which connects to the horn button on the new wheel.
Old Nov 28, 2003 | 06:43 PM
fd3virgin's Avatar
thanks i will try it.
Old Nov 28, 2003 | 10:31 PM
fd3virgin's Avatar
ok, now what. can't seem to get the horn to work. when i touch the power wire to the metal that's inside the steering the horn beeps all the time continuously. when i move it, it stops. when i just put the power to the rubber horn that you depress and put it in ...i get nothing any ideas would be nice.
Old Nov 28, 2003 | 10:40 PM
fd3virgin's Avatar
here's the horn piece with the two connectors.
Old Nov 28, 2003 | 10:43 PM
fd3virgin's Avatar
oh yeah is the metal ring in the right place? the instructions that came with the wheel sucked. thanks.
Old Nov 28, 2003 | 10:52 PM
fd3virgin's Avatar
do i have to make a spring plunger contact with the metal inside the hub to make the horn go off when you press it.
Old Nov 29, 2003 | 02:29 AM
rockshox's Avatar
put the 2 wires on the 2 contacts on the back of the button. i think thats where the ring goes. its not exactly a vital piece.
Old Nov 29, 2003 | 06:17 AM
fd3virgin's Avatar
tried that didn't work. it's like i m missing a piece of the puzzle.
Old Nov 29, 2003 | 08:34 AM
allrotor93's Avatar
just remove the horn and get an air horn like me ...i am installing a semi air horn for xmas...should be pretty loud
Old Nov 29, 2003 | 03:36 PM
fd3virgin's Avatar
uh, anyone else.
Old Nov 29, 2003 | 03:57 PM
Batmobile's Avatar
FD3Virgin,
One wire has to be grounded and the other wire has to be spliced into horn wire(I forgot what color) if I remembered correctly. Remember to give the horn wire a lot of slack. If you don't, when you turn your steering wheel, the wire will just snap off LOL(from experience).
Old Nov 29, 2003 | 04:55 PM
fd3virgin's Avatar
i grounded the black wire. it was already grounded to the hub. for the power to the horn i took the wire from the orange connector/ red/green and hooked it straight to the horn. still don't work. maybe i will call momo.
Old Nov 29, 2003 | 05:44 PM
911GT2's Avatar
The Power of 1.3
Thats the Millenium wheel right? I LOVE that wheel, it's on my list of things to get, and damn, it's just so puuurty.
Old Nov 30, 2003 | 07:55 PM
fd3virgin's Avatar
allright guys thanks for the inputs. i got it to work. used a new ground. thanks.
Old Nov 30, 2003 | 08:08 PM
Batmobile's Avatar
Hey, good going! Nice steering wheel also!
Old Nov 30, 2003 | 08:20 PM
rockshox's Avatar
new ground? well anyways glad you got it working. heres mine
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
