$399.00 Driveshaft racket
Old Nov 23, 2003 | 02:34 PM
Unhappy $399.00 Driveshaft racket
After searching every local option for replacement u-joints in a non-servicable driveshaft for my 83, and checking on line with Mazdatrix, I finally resovled there was no option but bend over and order the factory (cheaper than Trix by $35.00) replacement drive line assembly...with replaceable u-joints.
As I await delivery to (tomorrow)...I found "mazda123x5" post of 10-27-03 regarding the same problem...and he was lucky enough to find a shop in Ca. to rebuild a "non-servicable shaft" for $65.00...
Why don't rx7 suppliers make a conversion kit readily available...especially a company as big as MazdaTrix.
Has anyone else been screwed on this scam?
Old Nov 23, 2003 | 03:08 PM
bouis's Avatar
Sounds like you f'd up, because Mazdatrix sells modified driveshafts for something like $250, not $435 -- that's what a new stock one costs.
natew's Avatar
FYI mazda trix isn't very big... Its just a little shop in cali.
Old Nov 23, 2003 | 03:28 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
i bought a NEW driveshaft with replaceable, regreaseable u-joints from a shop in bakersfield.
$350.00
Old Nov 23, 2003 | 04:36 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
Im getting a completely custom alluminum one with HD chevy style U joints for $400.
Old Nov 23, 2003 | 05:47 PM
Last week booted up Mtrix, prior to going to factory, loked up the 83, noticed the warning that 1983 was non-servicable...then went to the price, $436 plus frieght. OUCH!!!
Couple of days ago I dropped the old shaft out, ( took longer to jack the car up than to remove shaft), then headed to our local driveline shop in search of any U-Joint that would fit....nothing around this part of the counrty. Literally got sick today when I discovered another owner had found a "Reasonable Shop" to make the conversion.
What the heck, I miss my RX, and look forward to a vibration free ride....we all know how joints ease up on you....the vibration has slowly been creeping up for monthes...and like other owners...I looked everywhere else....first.
Old Nov 23, 2003 | 06:08 PM
bouis's Avatar
Mazdatrix sells the '83 driveshaft for like $240 with replacable u-joints.
Old Nov 23, 2003 | 06:15 PM
mazdaverx713b's Avatar
Have RX-7, will restore
i wish i had known you were looking, i would have sold you one with good u joints for 50.00. at least you know you're gonna get good use from it and know for sure it will last.
Old Nov 23, 2003 | 07:58 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: $399.00 Driveshaft racket
hudson machine shop does them here all day long for $35+parts
Old Nov 23, 2003 | 09:43 PM
Barwick's Avatar
SCCA Rookie
I'm picking myself up a custom carbon fiber one (rather have my driveshaft broom if it breaks, than pole-vault my car). Weight savings is like nil, but much better for safety.
Old Nov 23, 2003 | 09:48 PM
how much is that costing?
ive heard Carbon fiber shafts are better for driveline life also.
Old Nov 24, 2003 | 05:22 AM
inittab's Avatar
I read your email
Re: Re: $399.00 Driveshaft racket
Do you have any contact info? Maybe I'll ship mine to them.
Old Nov 24, 2003 | 11:46 AM
When my 84's driveshaft went out I took the rear yoke off of the rear-end of an 81 and swapped it with mine.
A regular 81 driveshaft will not bolt up because the bolt pattern is different, that is why I swaped the yoke.
Now I am able to use 81 driveshafts which have replaceable universals for about $9.
The car I got the yoke and driveshaft from was 50 dollars from my local impound, it would have been free if I was able to get it before the impound did.
Old Nov 25, 2003 | 11:51 AM
Thanks for all the good feedback, and I wish I would have looked around this web before I went to the Mazda Parts Counter.
Be advised that I ran a copy of the Sunday Responses to my dilemma, carried into my Parts Man yesterday....and refered to the shop in Ca. that would rebuild for $65.00, the guy took pity on me and knocked another 50.00 off...so I'm out the door with a new shaft w/replaceable joints...$350.00
Your responses saved me $50.00 so thanks to all!
Old Nov 25, 2003 | 12:14 PM
GirlsDriveFast2's Avatar
Carbon fiber shafts and Aluminum shafts take off your time in the 1/4 mile cause of the Less rotating mass, and if you add one on with a lightned flywheel it has a big provement but man my brother spent alot for that.
Sorry that it cost you so much.
Old Nov 25, 2003 | 12:23 PM
bouis's Avatar
I feel like I want to jump up and down. One more time:
M a z d a t r i x
s e l l s d r i v e s h a f t s w i t h r e p l a c a b l e u - j o i n t s f o r $ 2 4 0.
Why pay more?
series1rx7
Sep 27, 2015 05:46 PM
