GSL-SE Rear End in an Rx2
Old Nov 16, 2003 | 12:48 AM
Jaime Enriquez's Avatar
OLDROTA
Anyone know how hard/easy it is to put a complete SE rear end in an Rx2? Any previous experiences? Need the LSD, 4x114.3's and the strength. Any difficulty in finding decent used SE rears?
Old Nov 16, 2003 | 09:12 PM
RotaryRevn's Avatar
Great question, I would be interested in the same swap
Old Nov 17, 2003 | 07:56 AM
Siraniko's Avatar
RX for fun
straight swap only:
RX-2 and RX-3 SP, use up to 83 gsl.
non-rx-3 SP has long pinion shaft, therefore, its either modify your driveshaft or find a SP drive shaft.
Old Nov 18, 2003 | 12:22 AM
OLDROTA
The driveshaft mods aren't a problem as I plan to eliminate the 2-piece Rx2 shaft in favor of a custom one piece unit anyway. I need to know if the lateral links, shock mounts, and stock panhard bar will match up or do I need to modify the mounting points...
Old Nov 18, 2003 | 08:30 AM
Siraniko's Avatar
RX for fun
79-85 wheelbase = 95.3"
RX-2 = 97.2"
RX-3 = 91
RX-4 = 99
R100 = 89
Old Nov 18, 2003 | 05:20 PM
69 510 13B's Avatar
I need to know if the lateral links, shock mounts, and stock panhard bar will match up or do I need to modify the mounting points also. I have a '85 GSL parts doner that I'd to put it LSD rear axle into my '74 coupe???
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
