I have 60mm gauges, but the center chanel pod is 52mm....What to do?
Old Nov 13, 2003 | 11:06 PM
Mazdabation's Avatar
Before I begin, yes a search was done...........
Ok, I have the Tripower 52mm center speaker gauge holder, but I have decided to go with 60mm gauges.
Everything I have read says to drumel out the plastic to make them fit, but I dont want to do that incase they don't fit in depth!
What are my other options? I dont care if its center chanel or A-Pilar, I just need 60mm holders.
Old Nov 14, 2003 | 12:30 AM
BigIslandSevens's Avatar
measure the depth of the pod and then the gauge and bam!!! There's your answer. And Dremel is a good idea if there is enough material.
Old Nov 14, 2003 | 12:32 AM
Does anyone know if i can buy 60mm holders in either the center chanel or A-pillar?
This way I wont ruin the 52mm and I can sell it to someone that may need it.
Old Nov 14, 2003 | 07:42 AM
racer1's Avatar
flying apex seal
I don't think that for the center mounts there is enough material to enlarge. You can get a 60mm pod from here though: http://hometown.aol.com/flyrx7/Rx7-Gauge-Pod.html
vmerino
Sep 5, 2015 11:26 AM
