Will a S4 N/A auto starter work on a S4 N/A 5-speed?
Old Nov 13, 2003 | 11:40 AM
Rxmfn7's Avatar
Do a barrel roll!
I just need to know if a S4 N/A starter from an auto will work in a 5-speed. I can tell that the motor part is much bigger on the auto starter, but the actual gear part looks identical to the 5-speed. Will it work?
wozzoom's Avatar
Nope. The mounting points are different.
Old Nov 13, 2003 | 11:50 AM
KiyoKix's Avatar
13B N/A POWA!
Damn
Old Nov 13, 2003 | 11:57 AM
hypntyz7's Avatar
All 5sp NA starters work on all other 5sp NA cars.
All automatic NA starters work on other automatics, as well as turbo II's.
Turbo II starters can work on automatics, although they are not as strong, and may not turn it as quick as it should be at startup (torque converter requires more power to turn, thus a stronger starter motor comes on the automatic).
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
maikelc
Aug 24, 2015 11:04 AM
befarrer
Aug 14, 2015 04:18 PM
